With a DKT 2xx0, you're probably on a DK-XX system
Try these steps
Leave phone on hook
Press REDIAL
Press SPEED DIAL
Enter Speed Dial Bin Number:
(Small system is 10-49 personal, 60-99 system-wide)
(Medium system is 10-49 personal, 600 - 699 system-wide)
(Large system is 100-139 personal, 200-999 system-wide)
Enter phone number
Press REDIAL to lock in number
If you're on a CiX system:
Press #9876
Press SPEED DIAL
Press Bin Number 100-199
Enter phone number
Press Speed Dial
Lift handset to lock in
ou can save up to 8 phone numbers in your speed dial book. The speed dial keys go from 2 to 9. When you place a call, our system prompts you to "enter the phone number you wish to dial". You just press the appropriate speed dial key followed by the pound sign (#) and your call goes through. No long numbers to enter any more!
If you set a speed dial for our access number on your phone machine, you have to press three keys only to complete a dial - as easy as "1-2#"! That's it!
For example, you can set your parents' phone number as speed dial key 2 and your friend's number as key 3. After dialing the access number from your phone, you will press 2 then # to reach your parents, or press 3# to reach your friend. Nothing could be easier! Speed Dial set up Instructions: Dial the access number, wait for prompt. Enter PIN number, wait for prompt. Dial: "#" "2" "#" [a speed dial number: 1-9] "#" [destination number] "#". The system will confirm the number. Example: [#] [2] [#] [5] [#] [011-888-88-88-88-88] [#] Use Speed Dial: Dial the access number, wait for prompt. Enter PIN number, wait for prompt. Dial: [speed dial key (1-9)] "#" Hope this will help to solve the problem....
Would need to know the phone model, there should be a way to set previous called numbers to a digit speed dial 1-10 etc. If you have a smartphone, Iphone does speed dial as favorites which are set up in the call menu. Droids have a specific icon for speed dial.
1) To program
a personal speed dial number, leave the handset on-hook.Press ALM/SD followed by the DSS button where
you want to store the number.Dial the
telephone number to save, up to 30 digits (press HOLD to insert a 3-second
pause or MSG in insert a hookflash).Press ALM/SD to store the number. 2) To dial a
speed dial number, select an outside line.Press the ALM/SD button.Dial the
desired speed dial code 10-98 (system speed dial) OR press the desired speed
dial button on your phone (personal speed dial). 3) System
speed dial numbers may only be programmed by the system administrator.
Go to your phone call settings and activate speed dials feature.
Then come back to your phone in normal display mode,press and hold any desired digit e.g 2,3,4,5,6,7 on the key pad and follow the prompt for assigning of phone nos for speed dialing.
So I guess that means you're not programming SYSTEM speed dial numbers. Those are programmed from the system manager or operator's station. Personal speed dials are 1-0 and are programmed per set.
what system u using??if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone. - to set speed dial press REDIAL SPEED DIAL standard speed dial code 60 or 600, follow by 9+destination number, REDIAL to confirm. - to call press speed dial + code or press * + speed dial code (*60 / *600) - if CTX/CIX must set at adminsrater phone. #66, speed dial code number (200-999), 9 follow destination number # - to dial press *200...
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed. Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
