Question about GE Refrigerators
My ge refrigerator looses it coolness about a week after i defrost it. after it is defrosted it works very good for a week and then starts to lose coolness and freezing capability. Can you help with this problem?
  • Mike Smith
    Mike Smith May 11, 2010
    Need the complete model number to be able to help you .
  • 415 Answers
You must repair the cause of failure the in most common cases the mother board but before order an expensive part first check the defrost heater... is it ok by ohming it out, then check the thermostat at the top of the evap coil it is round about the size of a plastic coke bottle cap when you ohm it out does it show a reading or is the cap split or warped if so replace it if ok. then the main mother board located at the back of the frig and has a covered panel about 10''' x 14''
Posted on Sep 10, 2009
After defrosting the freezer, both the freezer and the refrigerator side work great for about 2 weeks. Then the refrigerator side will not cool below 50 degrees. If we shut it off and let it defrost...
Old fashion ice box's had to be defrosted by hand like yall are doing now. Apparently the defrost timer, the defrost heater, or the defrost termination thermostat has took a dump. It takes about 2 weeks for every thang to clog up in a evaporator.
I wrote a tip about it and included links to service manuals HERE
Apr 13, 2011 | Kitchen Ranges
I have a GE side by side refrigerator, model GSL85JFPHBS. It sstopped working altogether last month. first the refrigerator stopped working, two day later the freezer part stopped working. I had someone...
I think you meant you have a GSL25JFPHBS (not 85).
It sounds like you have a defrost problem. If your refrig. was off for some time, like a day or more, or it was manually defrosted, it would work for about 2 weeks before the problem would re-occuer. This is caused by a build up of frost on the cooling coils, preventing air flow over them. Un-load the freezer and remove shelves and the back wall inside the freezer. Melt the frost with a hair blower, and replace the defrost heater (part # WR51X10055) and for good measure, replace the defrost thermistor (part # WR55X10025) located at the top of the cooling coils.
Mar 21, 2011 | GE Refrigerators
GE side by side w/Ice Denspenser. #TFX27ZP. Three times my frieg stopped working gradually. after removing everything it began to work again. I have tried to put minimal items in both the refrieg....
It seems as though your fridge is sticking in the defrost mode...try replacing the defrost timer/control...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 01, 2010 | GE Refrigerators
After about a week have to turn unit off to defrost,then runs fine for about another week
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 08, 2010 | GE Refrigerators
Refrigerator Model TFX22KRDA. The evaporator located in the freezer ices over and loses cooling capacity. When turned off and the ice is removed, the freezer and refrigerator both work fine for a few weeks...
heatman101
Aug 29, 2010 | GE Refrigerators
Ge refrigerator & freezer not cooling - frost build up on back wall of freezer
You probably have a bad defrost heater behind back wall of the freezer if you turn the unit off and let it defrost a fan will help speed this up the unit will run for about 2 weeks giveing you time to get a defrost heater GE have glass tube heaters and they are bad about going out good luck
Mar 31, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
