Assumeing you have already checked the outlet/surge protector has power. This is probably one of a could be a couple of things. Either the power supply or the motherboard. One thing you can check is to remove the side cover from the computer and see if the MB has any lights on, normally green or red, if not I would start with the power supply.
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter. If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop. If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard. You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty. This can be repaired, but requires the laptop to be completely disassembled. I suggest you get a quote first.
turns on but just has blinking 3.5 diskette icon w/ ? in it. tried command key w/ ''s'' but nothing....
(More)
turns on but just has blinking 3.5 diskette icon w/ ? in it. tried command key w/ ''s'' but nothing. can't even get the caps lock light to come on.
HP Compaq 5311SR Desktop with XP. I changed the power supply but am unsure on which connector...
(More)
HP Compaq 5311SR Desktop with XP. I changed the power supply but am unsure on which connector attaches on the bottom front. I am looking for some kind of chart to verify which number connectors go where. P3, P2, P4, etc.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
