I need the full load amp rating of the Trane YHC063A. I have the minimum circuit ampacity, the max fuse and the max circuit breaker already
  • 20 Answers
Look on the rating plate on the unit itself - look for something labled as FLA. If you don't have access to the condensing unit, go to WWW.TRANE.COM and search for your full model number.
Posted on Sep 10, 2009
The wire in my house for an elec. garage heater is 14 gauge wire with a 15 amp breaker. I assume i need at least 10 gauge wire with 20 amp .The heater is 20.9 amps and 3000-5000 watts, with 17500 BTUs
Curt, a 20 amp breaker will blow if you pull 10.9 amps from it. I suggest having a licensed electrician do your wiring. Likely, you need a permit anyway.
Oct 22, 2015 | Water Heaters
Need Minimum Circuit Ampacity and the Maximum Fuse Breaker for the Condenser - Thak you
Serial numbers don't tell much.
Model. numbers describe the unit best an 18 in the model is for 1 1/2 ton,24=2 ton, 30 =21/2 ton 36=3ton etc
May 02, 2015 | Heating & Cooling
I believe I might need to change my (20 amp) breaker switch that is running on 10-2 wire which supplies power to my Rheem Classic 10 Seer. I'm not sure if I need to have 220V of power on a 30amp...
Hello, the unit runs on 220 volts that's why # 10 wire must be used. The best bet is to use a 40amp breaker for 220 volts, gives the circuit more protection.
Sep 04, 2011 | Heating & Cooling
I need to know the horsepower rating of the 8756 ice cream machine in order to match a 3 phase inverter to it
Standard is 208/230-60-3. Maximum Fuse: 45 Amps. Minimum Wire Ampacity: 3A. -220/380-50-3.
Maximum Fuse: 30 Amps. Minimum Wire Ampacity:27A.
Jan 11, 2011 | Taylor Ice Cream Makers
Hi, my 90 amp cutler hammer breaker (for my ac system) went out. All I can find at the moment is a 100 amp unit is that ok to use?
You will need to check the name plate rating of your A/C it is possible that you may not even need that large of a breaker. Most of the older units that had straight electric heat strips used this large of a circuit. If it has been changed out chances are a different size will be needed. On the nameplate there will be a minimum circuit ampacity and a maxi-um over-current protection that is the boundaries for your breaker size. If you do have a larger breaker on than what the unit calls for it could cause more damage to the unit if a problem occurs. Good luck!
Sep 09, 2010 | Cutler Hammer Brh290 90 Amp 2 Pole Circuit...
For an 3 Tn unit- single phase- 220 V a.c and gfor
There should be a full load amps or rated load amps on each of these units on the rating or nameplate. The ampacity or fuse size and wire size, which I think that's what you are wanting to know . The fuse size would be full or rated load amps times 125% and the wire size depending on the length of the run, 50 feet or less, (15 amps 14 gauge wire), (20 amps 12 gauge), (30 amps 10 gauge), and (40 amps 8 gauge).
Aug 11, 2009 | Heating & Cooling
Pioneer 12v car amp rated at 1200 watts max requires ? amp fuse
Hi I would suggest 40A (i know guys will disagree) but you shouldnt be running at full 50A. Fuse are often rate at 50% - 75% of the actual consumption. By the way, 8 guage @40A will give you about a 2% drop at 5 feet. Maybe consider heavier for 40A?? Just a suggestion
Jul 24, 2009 | Audio Players & Recorders
What if the full electrical load for the dtc95df
As the dtc95df needs to be wired directly into a cooker outlet it suggest that the appliance needs a minimum of a 30amp circuit.This is to cover all electrical side of the oven being on at the same time.The cooker circuit must be wired in a minimum csa twin and earth cable of 6.0mm and switched through a double poll switch.This would be fused back at the main db board with a min 30amp breaker or 45amp breaker.Cooker switches are rated at 45amp. hope this helps
Jul 19, 2009 | DeLonghi CTH2003 2-Slice Toaster
How to determine electrical power panel load capacity
The total panel ampacity should be rated first by your load, then by the main breaker. if you are feeding it out of another box, it will probably be a double 100amp. In that case you will probably use 100amp SER cable.
Mar 30, 2009 | Thomas & Betts Electrical Supplies
Heating & Cooling Logo
166 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
