Question about Rheem EcoSense by 7.4 GPM Outdoor Tankless Water Heater Natural Gas
Can not get lighted goes on and off - Rheem EcoSense by 7.4 GPM Outdoor Tankless Water Heater Natural Gas
  • otah May 11, 2010
    what is the error code omn the control
    Champion:
  • 248 Answers
Overheat stat or fan
Posted on Oct 12, 2009
Pilot light ok when release finger pilot goes out
Your thermo couple is bad. Thats the copper tube that goes from the gas valve to the pilot. It senses thats the pilot is lit. Thats not working thats why it goes out. You can get a new one at lowes or home depot for about ten bucks its pretty easy to change just dont kink it when you put it in. It will just plug in at the pilot and screw in at at gas valve.
Jan 11, 2013 | Bosch Worcester Spark Electrode...
WATER HEATER GOES OUT OVER NIGHT
you either have a back draft blowing out the pilot light, or a bad thermal coupling. if coupling is bad it will shut down the gas flow therefore shutting off pilot light. its a safety measure to stop the gas flow if pilot goes out. replace thermal coupling, that may do it. good-day ! but shut off gas first !
Mar 21, 2012 | Water Heaters
RRGG-10N60JKR /Pilot lights then goes off emedeitly
This indicates a problem with the gas valve, have it replaced.
Jan 19, 2012 | Rheem Water Heaters
I have a Kenmore Power Miser 12 gas water heater that the pilot light keeps going out. The water heater has been in service for 45 months. The pilot light has a blue flame with some orange flame flares...
check and or replace the thermal coupling. the coupling goes into the main gas control, if the coupling is bad it will shut off gas supply. as a safety measure.
Mar 09, 2011 | Water Heaters
The pilot light goes out. When I go to re-light the pilot and turn the temp for vacation to medium the flame goes out again.
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Nov 26, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
I had a water heater blanket installed on my gas water heater. The installers made a mistake and covered the air intake vents. Now I have removed the blanket but cannot get the water heater to light...
Since the pilot light stays on, and the main burner comes on momentarily, then goes out. This mean to
say that the gas supply is not steady, it also goes off.
You got to get your gas valve repaired or replaced to get
it working.
Nov 26, 2009 | Water Heaters
Pilot light goes out after water heater shuts off.
sounds like the wiring is backwards check the wiring
also check the thermo coupler
Jul 27, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Pilot light in water heater lights and then goes out
turn gas off the then back on then light
Jul 11, 2009 | Water Heaters
Water heater won't run long enough for hot water.
Common problem if the thermo couple goes bad.Replace thermocouple with a universial on.A common hardware item.
Dec 14, 2008 | Water Heaters
Rheem EcoSense by  7.4 GPM Outdoor Tankless Water Heater Natural Gas Logo
50 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
