Question about Kenmore 22422 Top Load Washer
Kenmore top loading washer 70 series
The machine will not drain or spin. I am just getting a humming noise.
What could be my problem? I brought the machine new 5 years ago
    New Friend:
Answers not more questions....
Posted on Nov 13, 2012
Hi I have a kenmore that is moving when it spins....some water left when spin is completed. We recently moved the machine to clearn behind it and this issue started. movement is about an inch per cycle.....can you help? thankse ,pde 22422
Posted on Dec 13, 2007
My kenmore series 70 washer wont drain or spin i jumpered out the lid switch but it still dont work
Does your machine make any noise(humming or slight whine)? If so then something may be seized, try spinning the tub by hand, if it moves then it may then be the motor itself is seized. Test power(with ac 120v meter) at motor, which should be located underneath the machine, just under tub.If you have power right to motor, then it is very likely that it is your motor. If no power to the power, then something in your selector switch has malfunctioned; continue to follow your power supply until you find the short.
May 25, 2012 | Kenmore 24932 Top Load Washer
Kenmore series 70 washer will not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
Kenmore Series 70 washer, does not spin out the clothes like it used to. Makes a noise it didn't used to. Sounds like a dryer that has clothes with metal buttons on it.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Aug 31, 2010 | Kenmore Washing Machines
Spin cycle does not drain water. The washer just stops when it gets to the spin cycle. The washer is a 70 series heavy duty.
heatman101
Aug 30, 2010 | Kenmore 24032\24036 Top Load Washer
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
My 70 series Kenmore washer will not spin
REPLACE MOTOR COUPLER/ IT FIXED MY WASHER SAME PROBLEM, DIFFERENT MODEL. HOPE IT HELPS YOU.
Feb 03, 2009 | Kenmore 23822 Top Load Washer
Not draining and spins a little but makes a whirring sound
you need to clean your pump something in your pump is causing your motor to work harder
Dec 26, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 series agitates but does not drain or spin cycle.
If the unit is not draining or spinning it sounds like a lid switch. If the unit is draining but not spining it sounds like a drive coupling.
Dec 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer
Does it hum or click? If it clicks your coupler is out or a hum could be a faulted gearcase.
Aug 19, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
278 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
