Question about Karcher 2500 PSI Pressure Washer
Excell vr2522 - picked up 2nd hand, cant figure out how to get unit to spray chemical? is there a chemical bit for this model? it appears to all be one peice
    Problem Solver:
  • 18 Answers
Use black tip or lowest pressure tip
Posted on Sep 12, 2009
Use the black tip or lowest pressure one that should solve your problem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Did you check the hose that goes into the resevoir.
Vitally
Posted on Sep 09, 2009
Both of my hands are so itchy I cant hardly tolerate it. I had this once before and I went to ER and they told me it was contact dermatitis
chemist > get an off the shelf dermatitis or eczema cream
GP .or back to ER
an allergy test would help know what chemical you are reacting to
Irritant contact dermatitis on the fingers and spaces in between them, caused by contact with allergens and irritating substances like chemicals. There is another specific type of hand eczema called pompholyx or dyshidrotic eczema, which causes small, itchy blisters to appear on the palms of the hands.
Jan 25, 2017 | Health & Beauty
How to replace wheels on Excell VR2522 pressure washer
Anon, The wheel is probably held on by a push nut/cap. The easy way to remove is to cut through the cap retainer with a dremel tool part way and pry off with screw driver, these caps are not normally reusable after removal, check hardware store for replacement.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DeVilbiss Excell VR2522 Type 0 Gas Pressure Washer Parts
Remove CM 1200 Lawn Mower Wheel Retainer Clip on Lawn Mower Wagon Carriage...
https://answers.yahoo.com/question/index?qid=20130208122204AAcj7mW
Jan 28, 2013 | Garden
What type of chemical hand warmer lasts the longest?
Your best bet is to avoid those chemical hand warmers completely. I think your best bet is to pick up a Zippo hand warmer, which lasts for up to 12 hours. It definitely kept me warm on my last hunting trip. Plus, you can refill it with lighter fluid when it runs out.
Dec 31, 2012 | Camping, Backpacking & Hiking
Excell vr2522 pull cord jammed
Is the garden hose connected and turned on?If so make sure that the trigger on the gun is being pulled while your trying to start the engine! The backed up pressure in the high pressure hose can mimic a blown or seized engine in this situation.
Apr 15, 2012 | Garden
Have an Excell 2500, VR2522...... Pull cord broke and now i think the spring is broke; where can I get a new spring and directions to reassemble the pull start?
That pressure washer uses a Honda 5.5 hp overhead cam engine
You need to get the model number of the Honda Engine and then Click Here to go to the ereplacementparts.com website and put the engine model number to order the parts.
Jun 23, 2011 | Garden
Excell r 2522 presure washer pump rebuild
I like http://www.ppe-pressure-washer-parts.com/excell-vr2522-replacement-parts-pump See pump upgrade and compare to rebuilding. Another good site is www.pressure-washer-parts.com. Piston seals usual begin by overheating from excessive idling. You might add a thermostatic relief valve to help this.
Jul 25, 2010 | Honda Garden
Fuel mix for a excell VR2522
should be a honda gcv 160 5,5 horsepower engine.
do a search for honda engine carburretor adjustment, plenty of pages on the internet detailing how to adjust carbs, mixture etc.
Excell Pressure Washer Model VR2522 Replacement Parts repair kits ...
lok at this site , parts breakdown of engine etc
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
We have mitsubitshi mr slim air conditioners one of the units has what appears to be mold inside the unit. one repair man wnat s to take the unitis off and clean them out anotjer says he would...
it is not always normal but it does happen and there is a chemical that can be spryed right into the coil and pan that is very affective not necessary to pull off the unit
Jun 18, 2009 | Heating & Cooling
No pump pressure
Sounds like the diaphragm in the pump unit has failed, the engine and the pump are two seperate things the engine only operates the pump but if the diaphragm is leaking or broken you wont get any pressure
May 22, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
468 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
