Question about Maytag Atlantis MAV6000 Top Load Washer
Washing machine will not spin
The machine washes, but then will not complete the rinse cycle, it will however pump out the water when dial is turned to that position, is it possible to get a drawing of the machine and how it works
  • 4 more comments
  • carolstitch Dec 10, 2007
    will not spin all the water out of the clothes when on the spin cycle
  • seahawkdodge Jan 28, 2008
    I'm having a similar problem. It washes fine, then starts the rinse cycle. It will fill with water, but won't drain or spin all of the time. Usually I would have to restart the rinse cycle, and it would finish up.
    Yesterday, however, I noticed it had not drained. So I manually tried to restart it, and realized that the breaker had blown. I reset the breaker, and it started making a very strained buzzing noise, and I started to smell burning electronics...so I unplugged it.
    ae2bryant@yahoo.com MasterTech, I would appreciate it if you could forward that to me. Thanks!
  • Vickie77 Mar 23, 2008
    Master Tech, we are having the same problem too but the model # is a little different. It's an Alantis MVAV9600EWQ. I wasn't able to get a manual either from the Maytag website.
    We would appreciate it if you could email us (if you have one) a manual for this washer.
    Thanks, Vickie
  • tamkev Mar 26, 2008
    My maytag pav200aw will not spin. I have replaced the motor but when it gets to the spin cycle the motor buzzes and nothing happens. I do not have a diagram so was wondering if one of the wires is not connected correctly.
  • DurkE Mar 30, 2008
    I have just encountered same problem. Rinse ok. Pumps water out during spin. Tub doesn't spin. Am looking for an isometric of the washer and possible problem/solution.
  • 770 Answers
Post your email i will send you the manual on your unit
Posted on Jan 27, 2008
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Why is my whirlpool auto load sensing washing machine spraying water while in final spinning cycle?
you could have a bad temperture sensor bad are water valve but first check an make sure the washer drain alway check your drain hose for clog are lint are trash in pump an last you could have a bad timer if you dont know how to check these call a applince service for repair ok
Dec 13, 2017 | Washing Machines
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
Washing machine does not complete wash cycle. Gets to rinse than stops. Does not rinse or release water. When I manually move the dial to spin, nothing happens?
You need to check the pump it sounds like you have something in it .Clean out the pump and the unit will finish the cycle if the pump is not burnt out.
Sep 18, 2011 | Washing Machines
Kenmore washer - water won't drain. It stops
If the water drains between the wash and rinse cycles, your motor and pump are probably OK. If this is a machine with a dial, try a different cycle, like normal instead of heavy duty. If that works and the machine completes the entire cycle then the timer probably has a bad spot. You might try to find a replacement timer if that is the case although I didn't have any luck with my 10 year old washing machine. Best of luck
Mar 20, 2010 | Washing Machines
Unit runs good through wash cycle then while in rinse and spin does not complete cycle. The machine starts doing a short spin, and then dial starts turning around without stopping.
Sounds as if the drain pump is not ejecting the water fast enough. Did you notice of the washer is draining more slowly than usual or at all?
Feb 14, 2010 | Splendide 2100 Vented Washer-Dryer
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Washing machine will not drain
TAKE THE HOSE OFF ON THE BACK {DISCHARGE HOSE} IF THE WATER FLOWS OUT IT IS THE PUMP MOTOR IF IT DOESN'T THERE IS SOMETHING BLOCKING THE OUTLET, SMALL CLOTHING ITEM
May 29, 2009 | Indesit W 123 Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
85 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
