Question about Wilson Watches
Crown of Titan 9G1 watch purchased 1998 needs replacement -
Crown of Titan 9G1 watch purchased 1998 needs replacement - Sydney service available?
  • 3,051 Answers
Hello there:
if you are in the sydney or the melbourn or pearth area there are several watch dealers avaiable for you just look up the watch maker and the model of the watch and look for local dealer ok ?
best regards michael
USN RETIRED
Posted on Sep 09, 2009
How do I wind a Cartier ballon blue watch ?
more than likely it has a screw down crown. Turn the crown towards you to release it from the case tube then wind it forward. Make sure that you tighten the crown when finished winding it or you will get water into the watch.
hope this helps, gabe.
Oct 22, 2014 | Cartier NEW CARTIER BALLON BLEU LADIES...
DATE WONT CHANGE
If you have the crown in the first click position (date set position) the date set wheel is most likely damaged. Otherwise, if it does not change in 24 hours, it is the date wheel itself that is damaged.
This happens in all watches over time, as even quartz watches must technically be serviced every 3-5 years. 90% of manufacturers quote this as the standard service rate for quartz and mechanical watches.
If this watch has sentimental value, and you will want to contact a local Certified Master Horologist or Certified Quartz Technician about replacing the movement. Replacing Timex movements is generally more expensive than purchasing a new watch.
If the watch is still in warranty, you may consider contacting Timex about replacing the watch free of charge at: custserv@timex.com
Feb 04, 2011 | Timex Expedition 43892 Wrist Watch
I need a Crown for my nike watch
mcdevito75 here, Best bet, look for a small watch repair shop in your area for a replacement crown. If the crown broke off however, you need a new crown and stem.
Jul 09, 2010 | Nike Watches
I had my Rolex watch serviced 2 years ago By Rolex and now
Either the stem or latch needs to be replaced. It's a common problem for ALL manual wind watches.
Dec 06, 2009 | Rolex Watches
My crown fell off the stem of my Gucci watch. How
If you still have the crown you may be able to put it back on yourself. However for a secure repair you would need a watchmaker to repair this.
To try yourself get some RED locktite (available at any Ace hardware store or automotive store) Put a small amount on the threads of the crown. Then screw the crown onto the stem as much as possible.
Let it sit for about 10 minutes so the locktite can cure. Then you can try using it to set the time or whatever.
If this does not work you will need a watchmaker to repair this.
Prices to fix this would vary.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 01, 2009 | Gucci G Watch ladies' YA100510
Winder is lost
You need a replacement stem and crown. I would replace the stem just to be sure you arent putting a new crown on a damaged stem.
Sakgen is very good about repairing their watches. Unfortunately this doesnt fall under their warranty but the repair directly through them is an average price for this part.
Generic after market crowns are also available at local watch repair shops. Make sure that if you go this route that you select a shop that can reseal the watch to is water resistance rating so you do not void your lifetime limited warranty on the movement. This mean they must have a pressure testing chamber and be able to supply printed proof of resealing.
Sep 23, 2009 | Skagen 355LGSC Wrist Watch
How do I set the time and date on my Toy Watch?
The Toy Watch website has instructions on setting the time. Not sure about the date:
Setting Your TOYWATCH
1. Unscrew crown by turning it toward you.
2. Pull the crown out until you hear a click.
3. Turn the crown to set the time as desired.
4. Push in the crown and screw away from you until it is tight.*
* If crown is loose warranty covering water damage may be voided. crown_locked.jpg
http://toywatchusa.com/content/Setting.htm
Jul 16, 2009 | Watches
I cant find where to buy a new watch band
Dear Friend,
                 U can Purchase a new branded watch at Fast track which is one of the best brand among the watch companies.If u need to buy am Indian Brand then u can take a choice of Titan
Regards,
Aysaam
May 05, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Does anyone have a manual for a datejust rolex
No, there isn;t any downloadable manuals for Rolex watches, but operation of Rolex Datejust is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in date setting position,
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Feb 03, 2009 | Rolex Datejust SS
Watches Logo
82 people viewed this question
Top Wilson Watches Experts
Jimmy Accardi
Are you a Wilson Watch Expert? Answer questions, earn points and help others
