Question about Okidata B2500 MFP Printer Laser
Turning off the fax answer
How do I turn the incoming fax feature off i never received a manual
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Lexmark pinnacle pro901 will not receive faxes i can send but can not receive what do I do
Are you sharing your home phone line with your fax? Do you have an answering machine or a voicemail feature in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may want to subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Nov 02, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
How do I set the date and time and my hp passed all the fax tests but I do not receive faxes.
Follow the instructions below to set date and time on printer
Setting the date and time on an HP All-in-One Follow these steps to set the date and time from the control panel.
  1. Press Setup .
  2. Use the right arrow button (c00377082.gif ) to highlight Tools , and then press the OK button.
  3. Select Date and Time from the Tools menu and then press the OK button.
  4. Enter the month, day, and year by pressing the appropriate numbers on the keypad. After the date is entered, the Enter Time screen displays.
  5. Enter the hours and minutes by pressing the appropriate numbers on the keypad. After the time is entered, the Tools menu displays.
  6. Press the Back button to return to the main menu.
Follow the steps to solve "Unable to Recieve Fax" Issue
Basic requirement are..
1. Rings to answer should be 2 rings greater than your Answering machine rings or Voice mail ( set it to 6 instead )
2. Auto Answer should be on
3. Turn off ECM ( Error Correction Mode )
Use these steps to change the Rings to Answer setting.
  1. On the product control panel, press the setup button (c01661990.gif ).
  2. Use the right arrow key (c01661991.jpg ) to select Basic Fax Setup and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select Rings to Answer and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select the desired number of rings and then press the OK button (c01335940.jpg ).
Make sure that the Auto Answer feature is turned on When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls. To turn on the Auto Answer feature, follow these steps.
  1. Press Auto Answer on the product control panel. When the Auto Answer button is lit, the feature is turned on.
  2. Try to receive a fax.
Make sure that ECM is Turned Off ( Error Correction Mode )
  2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
Try to Receive Fax Now.
These steps should resolve the issue and you should be able to receive fax
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | HEWLETT-PACKARD HP 6500 All In One Printer...
How do I receive faxes with the 240c
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | Brother Multi-Function Center MFC-240C...
How to set machine to receive incoming fax?
Quoted from the manual: The HP all-in-one will not automatically answer calls. You must receive all faxes manually by pressing Start Fax Black or Start Fax Color. For information on receiving faxes manually, see Receive a fax manually. You might use this setting if the majority of calls on this phone line are voice calls and you rarely receive faxes.
This page has more information: http://www.fixya.com/support/p378554-hp_officejet_6210_all_in_one_inkjet/manual-3600/page-86
May 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How to fax forward?
You can set your product to forward incoming faxes to another fax number. When the fax arrives at
your product, it is stored in memory. Then your product dials the fax number you have specified
and sends the fax. If it cannot forward a fax because of an error (for example, the number is busy)
and repeated attempts to redial are unsuccessful, your product will print the fax.
If the product runs out of memory while receiving a fax, it will terminate the incoming fax and only
forward the pages and partial pages already stored in memory.
When using this feature, the product must be the one receiving faxes (not the computer) and the
answer mode must be set to Automatic (see Changing how the product answers incoming faxes).
To use fax forwarding
Press menu/enter.
2 Use the < or > button to select Fax Setup and press menu/enter.
3 Use the < or > button to select Fax Recv. Setup and press menu/enter.
4 Use the < or > button to select Forward Fax and press menu/enter.
5 Press > to select On or Off and press menu/enter.
6 If you choose to turn fax forwarding on, use the alphanumeric buttons to enter the fax number
where you want the fax to go, and press menu/enter to save your selection.
Apr 15, 2009 | HP LaserJet 3330 All-In-One Printer
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
If you have a voice mail service at the same phone number you use
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
If you have an answering machine on the same phone line with
your HP Officejet, you might have one of the following problems:
Your outgoing message might be too long or too loud to allow
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
Your answering machine might not have enough quiet time after
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
The following actions might help solve these problems:
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
be causing the problem.
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
If you have a special ring pattern for your fax phone number (using
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
(distinctive ringing)
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 20, 2008 | HP Officejet 4215v All-in-One Printer
Receiving a fax
The answer mode determines whether your HP All-in-One answers incoming calls or not.
If you set the HP All-in-One to answer faxes automatically, the HP All-in-One will answer all incoming calls and receive faxes. Set the Auto Answer setting to On.If you set the HP All-in-One to answer faxes manually, you must be available to respond in person to the incoming fax call or your HP All-in-One will not receive faxes. Set the Auto Answer setting to Off. For more information on receiving faxes manually, see Receive a fax manually. If you do not know which answer mode to use, see Choose the recommended answer mode for your setup.
To set the answer mode 1 Press Setup. 2 Press 4, and then press 2. This selects Basic Fax Setup and then selects Auto Answer.
3 Press right arrow to select On or Off. 4 Press OK to accept the setting.
Mar 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Okidata B2500 MFP Printer Laser Logo
77 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
