Question about Marshall Electronics V-LCD15-TV 15.1 in. Flat Panel LCD Monitor
CABLE CAN NOT FIND OUT OUT TO GET CABLE INPUT,CCAN ONLY GET CHANNEL 2 TO 15 NEED TO GO HIGHER
If chan 2-13, vhf tuner ok, uhf deffective...ch 14 and up are uhf...
Posted on Jan 09, 2008
Cable channel source goes up from channel 3 to higher channel?
First to check your cable resepction then replace your tv tuner same number your tv channel mistunes
Jun 09, 2015 | Prima Televison & Video
Cannot change channel on my Dynex DX-L26-10a TV
Try checking the signal strength then run the scan again.
Checking the DTV signal strength
You can check the DTV signal strength to determine if you need to adjust your antenna or digital cable input. The higher the signal strength, the less likely you are to experience picture degradation.To check the DTV signal strength:
1.Press MENU. The on-screen menu opens.
2.Press < or > to highlight Channel, then press v. The Channel menu opens. The DTV signal strength is shown at the bottom of the menu.
3.Press EXIT to close the menu.
Oct 26, 2012 | Dell Vostro 200 PC Desktop
Not sure what channel to put TV on to receive DISH channels
Hey there, Cheri Torres with DISH Network Internet Response Team here. I came across your post and wanted to see if I could help. The channel that you would need to put your TV on would depend on the type of cable you have plugged into your TV and receiver. If the cable you have plugged into the receiver and TV is a coax cable (black cable with silver end) the channel would need to be on 3 or 4. If the cable is a RCA cable (black with red, white and yellow tips) the channel would need to be on an input such as Video 1, input 1, input 2, aux etc. The other cable that it could possible be hooked up with is a HDMI cable (black with a thin flat end) the TV would need to be on a HDMI input. You can find the inputs by pressing the input, TV/video, source or AUX button on the DISH remote or TV remote. I hope this information is useful and if you have any other questions please let me know.
Nov 23, 2011 | iLO IWT3206 TV
The calble is connected directly to the tv, not through the cable box & when i try to change the channel it says "no signal" at the bottom left corner. Olevia 32" model 532-b12
I assume from your question that you have a cable subscription and that you have the cable plugged into the ANT input via a co-ax cable. The ANT input is for an antenna for over-the air signals. The channel up/down change the internal tuner up/down. For example, if your cable is set to channel 3, it will pull in the cable on channel 3, but then try to pull in over-the-air if you hit channel-up to channel 4.
It seems you need some kind of converter box from your cable company in order to change the cable channels, and then that converter box would plug into either the ANT input (and leave the tuner on 3) or into one of the other inputs like Component, HDMI, SVideo etc.
Feb 13, 2011 | Syntax Olevia 532H 32 in. LCD HDTV
Samsung tv power cycles when I get to higher channels pass 40. I attempt to change channel. Doesn't change and then front led blinks, tv screens goes blank, led flashes again and then screen is normal. I'm...
We have a similar problem when changing channels/surfing, the TV will begin to power cycle, until you unplug THE CABLE TV input, then it will turn on again and stay on as you rehook the cable and change channels....till it decides to do it again, DTV channels seem to trip it up, but not sure....if I leave it on the same channel it will run for days. Yep and the cable TV is grounded outside
Dec 19, 2009 | Samsung LN40A630 40 in. LCD TV
Channel 1 works fine but channel 2 doesnt put out anything. how can i fix it?
if you have indication of signal input for both channel you can go and reverse output cables of the speakers if the problem transfer to good channel change speaker cable-if you did not have input indication in the bad channel try to inverse input cable if it is cleared change your input cable if not you will have internal trouble and need service center to help.
Dec 14, 2009 | QSC MX1500A 2-Channel Amplifier
Channels
Sometimes the RC [remote control] has a MENU button that you can "bypass" any channel.Did you use the RC and 'delete' the channels by mistake?
Aug 15, 2008 | Sharp VC-A582U VCR
Tv channels
TV tuners will not go to any channel higher then 125. If you want to get the channel 500, you will need to have a cable box that are design to get all the higher channels.
Good Luck.
Aug 11, 2008 | Televison & Video
Tuning problem
Your TV is set to Antenna. You need to go into the menu and change it to Cable. Then do an autoprogram.
Jan 30, 2008 | Symphonic ST419E TV
Digital channels higher than 138
The channel setup is for freeview. Connect the Cable box Via a scart cable and view on the AV channel.
Jan 22, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Marshall Electronics V-LCD15-TV 15.1 in. Flat Panel LCD Monitor Logo
69 people viewed this question
Top Marshall Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Marshall Computer and Internet Expert? Answer questions, earn points and help others
