Question about Whirlpool Refrigerators
Ice maker overflows water during the water fill cycle
  • 415 Answers
Is the icemaker level side to side front to back if yes how is the water flow at the disp is it slow? then have you changed the filter in the frig ? No filter and water is still slow coming out follow the waterline from behind the frig follow it to where it hooks up if a saddle valve shut it off all the way use a hand towel to increase tork while shutting down then open it all the way open test the water at the disp again do you have better water flow coming out then the imkr may stop leaking the reason you are checking and testing the above is if you do not have at least 35psi of water pressure the valve will not close fully and overflow the icemaker another test is when you get water from the disp does the water shut down when released or does it continue to run/drip if so the water psi is the cause although useful not always as reliable
Posted on Sep 09, 2009
My Scotsman CE33A cycles on and fills with water then within 3 r 4 minutes the water volume goes down and wont spray up into mold.i can fill the resivor with water and it does fine until the water lev
In the water reservoir there is a tube that maintains the water height during operation. It fits in the overflow drain hole and keeps the water level at the proper level. This tube is either not installed into the bottom of the reservoir properly or it is broken.
Hope this helps
Feb 12, 2015 | Scotsman DCE33PA1BC 15in Built-in...
Why is my ice maker causing blocks of ice at the bottom of ice bucket ,also on freezer baskets ?
Sounds like there is a leak in the water fill line to the ice maker or the timer in the ice maker is defective causing the fill cycle to overflow the cube tray and then freeze into blocks in the freezer.
Oct 08, 2014 | Kenmore Refrigerators
Excessive Water Overflow
reduce the water pressure at the inlet valve so the trough fills up during harvest but doesn't overflow too much. There is a restrictor you can put in the valve entry, or you can just turn the tap to partly close it.
May 16, 2014 | Scotsman Kitchen Appliances - Others
Water keeps overflowing out of the sump trey continue running
Replace water fill float valve is letting water seep buy during freeze cycle and it will not make ice due to water too warm
Jul 26, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
My undercounter Whirlpool ice maker is not putting water in the bin on a consistent basis. It causes the pump to run dry. I am trying to determine if I need to replace the computer board or the water...
when you first turn the machine on it will go through 2 fill cycles. turn the machine off, and drain the water reservoir. when you turn the machine back on the first fill cycle should fill the reservoir and over flow a little bit. If it does not overflow then you are not getting enough water (change the fill valve). If it does overflow on the first fill cycle, the the machine probably needs acid cleaned. the instructions on acid cleaning are usually on the door. I don't believe the computer board would be your problem here. Hope this helps, CLINT
Feb 14, 2011 | KitchenAid KUIS18NNT 18" Automatic Ice...
Water overflowing in ice maker tray on a GE
make sure your refrigerator unit is level first . If it is , and you have eight square faced plastic cover on the front of the ice maker itself that can be removed by un- snapping it, remove it and see if there is a small screw with a spring underneath it or positive or negative arrow's on the unit where the screw is located. Regardless, if there is a screw all by itself turned the screw 1/2 turn Counterclockwise. this will decrease the amount of time the water valve is open during the ice bin filling cycle.
Mar 13, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Tube feeding ice maker comes off
Good day,
Common problem. Remove ice maker, and make sure tube fits all the way to the rear and seats properly.
Then reinstall ice maker and telescope front part of file tube until it fits into ice ice maker properly. (retaining clip in place).
For the cost, a new fill tube makes sense. Also.........
If the water valve leaks slightly after shutting off during a fill cycle, a plug of ice will build up inside the the fill tube, pushing it off on the next fill cycle. Requires installing a new water valve.
Nov 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Water dispenser spontaneously erupts when making ice
I had to fix a problem like this the other day you need a inlet solenoid
Aug 29, 2007 | Frigidaire FRS26KR4A Side by Side...
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
167 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
