Question about Linksys Wireless-G WPS54G Print Server
I have a netgear wireless network. I am trying to
I have a netgear wireless network. I am trying to install a linksys print server to be able to print from my laptop. I can get it installed on the desktop and can print from the desktop, but my wireless cannot find the printserver when I try to do the software install.
  • 674 Answers
You can use sharing printer.. even your are using wireless can print as long as you are connected on that network and secondly the same name of workgroup.
Posted on Sep 13, 2009
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
Connecting this print server
try unplugging both and then plug in the router,let it reboot, then plug in the other and let them find each other. if that doesn't work let me know.
Oct 02, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Can you connect it to your computer by wireless
Sure can. Just buy a wireless print server with USB output. They are made by most big names like: Trendnet, D-Link, Linksys, Netgear, etc. I see them on Ebay for low prices 5-20 dollars.
Just make sure you get a match to the router you have for frequencies. For example: G or N
Good Luck
Jan 03, 2010 | Samsung CLP 300 Laser Printer
How do I connect with my WGPS606 if there is no setup cd and the default ip does not work? My router has encryption and the WGPS needs the info.
you need to set your print server for dhcp, you need to log in and verify the settings OR just set it back to default because dhcp is default. gl
Nov 06, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
No print sharing. Existing but lder Belkin router has no problems, but WRT54g-TM will not print share. Have a Netgear switch box as well, can I integrate the two or even all three to solve print share...
If you are using a belkin router, wrt54g-tm and netgear switch box. Basically they won share the printing. you need a wireless print server..try the linksys WPS54GU2
Jul 28, 2009 | Linksys WRT54G-TM Wireless Router
Problem with Linksys Wireless-G WPS54G Print, PS can't be found.
Check the settings on your wireless print server. And as well check your router.
Jul 26, 2009 | Linksys Wireless-G WPS54G Print Server
Unable to setup wireless print server with wireless router
The issue was the wireless print server not properly connecting to my home network and thus being unable to see my modem/network. This was because my linksys wireless print server generates its wep key with a different algorithm than the Motorola surfboard SBG900, this also explains why when I was using my old linksys wireless g router, things worked without any issue (same wep key algorithm). Once I figured out how to manually configure the print servers wireless settings and manually enter the wep security settings I was able to connect to my network and the configuration found the print server and I was able to finish setup.
Nov 27, 2008 | Linksys WPSM54G Print Server
Installation assistant cannot detect print server
Results of attempting to connect the Netgear Wireless Print Server WGPS606 and the Canon MF6550 multifunction laser printer. I was on the phone for several hours last evening (March 9, until about midnight EDT) with a very competent support agent from Netgear (actually in the Philippines). The Netgear setup Wizard software would not connect the Print Server to my Verizon FiOS wireless G router automatically, so the Netgear support agent walked me through it manually. The Print Server connected that way, for sure. Then we manually attempted to connect the Print Server to my Canon MF6550 and subsequently, my HP 932C Deskjet. Neither printer is on the WGPS606 compatible list, nor is either on the known incompatible list. Now we know - both printers are INCOMPATIBLE with the Netgear WGPS606. I bought both the Netgear Print Server and the Canon MF6550 at Staples on Sat., March 8, 2008, based upon the assurance from Staples staff that it would all work. The question now is whether ANY brand of wireless Print Server will work with the Canon MF6550, or do I have to return this printer and get either a Canon with built in networking (ethernet or wireless) or switch to the Brother equivalent (MFC 8870DW). If I get a (multi-function) printer with built-in Ethernet networking, does the Ethernet capability bypass the USB incompatibility problem, or will the problem remain?
Mar 10, 2008 | NetGear WIRELESS PRINT SERVER 54MBPS...
Print server
i advise you to buy D-Link or Netgear print servers... they're the best in market
check them out here with price listed
LinkSys
http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=2029
Netgear
http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=781
Linksys will cost about 49 Pounds
Netgear will cost about 40 Pounds
Dec 26, 2007 | NetGear PS121NA Print Server
Linksys Wireless-G WPS54G Print Server Logo
279 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
