Question about Xerox Phaser 6110 Laser Printer
Deve home sensor error - Xerox Phaser 6110 Laser Printer
  • gerand177 May 11, 2010
    Here is some great PRINTER solution by Some FIXYA EXPERT.
    Get any kinds of PRINTER solution from bellow.
    » Brother Printer Solution
    » Canon Printer Solution
    » Epson Printer Solution
    » HP Printer Solution
    » Lexmark Printer Solution
    » Xerox Printer Solution
    » Other Printer Solution
  • 34 Answers
There is a problem in the fuser unit check component oven lamp thermistor and fuse thermostat etc. ..and then if not dispear the message you change main board
Posted on Sep 13, 2009
SOURCE: deve home sensor error
the transfer belt is worn or covered in toner or has a label stuck on it or the sensor is dirty.
Posted on Jan 06, 2009
ghassun
  • 499 Answers
SOURCE: Deve home sensor error
hi if u check the samsung manual herehttp://www.wisconsinimaging.com/downloads/clx3160manual.pdfthen u will find it in page 79 and it saysThere is a problemin the fuser unit.suggestion:Unplug the powercord and plug it backin. If the problempersists, please callfor service.
Posted on Jun 09, 2009
  • 68 Answers
SOURCE: DEVE HOME SENSOR ERROR
replace the toner cartridge
Posted on Oct 05, 2009
  • 12 Answers
SOURCE: i am getting deve home sensor error on my samsung
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
The problem is that the spring gets weak over time / the cogs round out over time and the solenoid finger is overcome by the spinning cogs, and resulting in selecting the wrong developer.
Open up the right side (power cord side) of the printer (take off top cover, then take off side cover). Then, find a solenoid (little metal square) that touches the white plastic vertical spur gear. Take the spring off the solenoid. Now, put the spring back on - only this time you will attach one anchor point to the middle of the spring as to pre-stretch the spring for more tension.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
Posted on Jul 10, 2010
  • 12 Answers
SOURCE: samsung clx-3160fn deve home sensor error
HOME SENSOR EROR
Deve Home Sensor Error
There is a problem in the fuser unit.
Unplug the power cord and plug it back in. If the problem persists, Replace to the Main board.
Aug 30, 2011 | Samsung CLX 3160fn All-In-One Printer
Get the error message at a samsung 2160 printer: error deve home-sensor. What can i do..........
Dear
Deve Home Sensor Error indicates a problem in the fusser unit.
Unplug the power cord ,check the fusser unit and plug it back in.
Main board.
Jan 16, 2011 | Samsung CLX-2160N All-In-One Printer
Deve home sensor error on samsung clx 3175
Dear
There is a problem in the fusser unit.Turn the power switch off and on. If the problem persists, call for service engineer.
Thanks.
Sep 24, 2010 | Samsung CLX 3160fn All-In-One Printer
I receive an error message DEVE Home Sensor error
May 29, 2010 | Samsung CLX 3160fn All-In-One Printer
The printer will not print I receive an error message
undr the scanner the is a lock.Unlock it...it looks like a switch.The scanner does not righ the home position
Aculaser 8500 error e525
EPSON AcuLaser C8500 Revision D
Troubleshooting Overview 5-19
1.1.4.4 Service-Call Error Messages
See the following tables for the detailed information on the Service-Call
Error messages.
Engine Related Service-Call Error
*1: Does not appear with this printer because the printer’s life ends earlier.
Table 1-2. Engine Related Service-Call Errors
Error Type
E
Error Code
fff Explanation FIP
E 113 Fuser Unit malfunction (No Fuser Unit) FIP-1.2
E 510 ROS motor malfunction FIP-1.16
E 511 Motor 1 malfunction FIP-1.15
E 512 P/H Motor malfunction FIP-1.14
E 513 NVRAM malfunction FIP-1.13
E 516 Duplex Unit malfunction (Communication) *
E 517 Optional single/double c*ssette malfunction *
E 520 2nd BTR malfunction (Advance) FIP-1.24
E 521 2nd BTR malfunction FIP-1.23
E 523 PCDC malfunction FIP-1.21
E 524 Toner density malfunction (Low density) FIP-1.20
E 525 Toner density malfunction (High density) FIP-1.19
E 526 ADC sensor soiled FIP-1.18
E 527 Deve home position sensor malfunction -
E 530 Environment (humidity)sensor malfunction FIP-1.27
E 531 PR Motor malfunction FIP-1.15
E 532 P/H Motor2 malfunction FIP-1.14
E 533 Thermosensor malfunction FIP-1.25
E 534 Fuser Unit malfunction (Low Temperature) FIP-1.26
E 535 Fuser Unit malfunction (Lamp) FIP-1.26
E 536 Fuser Unit malfunction (Time out) -
E 537 Fuser Unit malfunction (Overheat) FIP-1.25
E 543 Rear fan malfunction FIP-1.30
E 544 Fuser Unit fan2 malfunction -
E 545 Fuser Unit fan1 malfunction FIP-1.28
E 546 Duplex Unit motor malfunction *
E 547 Optional single/double c*ssette unit feeder
motor malfunction *
E 620 K Deve service life FIP-1.31
E 621 C Deve service life FIP-1.31
E 622 M Deve service life FIP-1.31
E 623 Y Deve service life FIP-1.31
E 624 IBT service life FIP-1.31
E 626 2nd BTR service life FIP-1.31
E 627 IBT cleaner service life FIP-1.31
E 830 Optional double c*ssette unit LC3
malfunction *
E 831 Optional single/double c*ssette unit LC2
malfunction *
E 832 MP tray malfunction (lift down) FIP-1.40
E 833 MP tray malfunction (lift up) FIP-1.39
E 998 Engine communication error FIP-1.43
Error Type
E
Error Code
fff Explanation FIP
conclusion :
check the toner if its well plugged. or correctly.
of its leaking or etc.
Feb 19, 2010 | Epson AcuLaser C8500 Printer
You could try replacing the Image Unit (but these are quite expensive). This error actually refers to an optical sensor located in the gearbox (RHS of machine). The sensor controls the drive to the individual dev units, hence the "dev home error" if it malfunctions.
Probably a job for an engineer.....
Jun 19, 2009 | Samsung CLX 3160fn All-In-One Printer
Jun 09, 2009 | Samsung CLX 3160fn All-In-One Printer
Deve Home sensor Error as occur cannot get printer to work
The web does not offer alot on this error. However the users manual indicates it is a fuser issue. Try a new maintenance kit. That should include the fuser and all rollers.
Dec 16, 2008 | Samsung CLX 3160fn All-In-One Printer
Xerox Phaser  6110 Laser Printer Logo
1,649 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
