Question about Kitchen Appliances - Others
Won't latch--lever goes down but won't latch - Kitchen Appliances - Others
  • 50 Answers
The spring arrangement responsible for this opration must be worn out or dislocated fix it.
Posted on Sep 23, 2009
My 1999 tyahoe hood latch and cable doesnt work how can iopen the hood
have someone push down on hood and try to open ---- reach behind the lever and disconnect cable use a vise grip to pull cable if cable is broken---- than behind grille is latch look through grill and will need a metal hook to grab cable and pull cable towards grille and pull through cut cable cover back and pull cable back
Hood latch won release ChevyTalk FREE Restoration and Repair Help for your... how to open hood from outside when cable breaks
Jul 28, 2016 | 1999 Chevrolet Tahoe
Hood won t close
Check out the cable connection between the latch and your internal latch control. Till you locate the problem I would suggest tying down the hood with some sort of strap so it does not pop open at speed.
Apr 24, 2017 | Chevrolet Malibu Cars & Trucks
Passanger side door locking problem. when I insert the Key, it can turn forward to lock the door, but can not turn backward to unlock the door. And I tried the second key, does not work either.
Really sounds like one of 2 possible problems.
First, perhaps the door latch itself is broken, and that is unlikely, except that I am unfamiliar with that particular latch on that particular car.
Second, it sounds like, if you were to take the door panel off, you would find the latch is locked because one of the locking levers is holding the door latch locked.
There or 2 or 3 lever like things that affect the latch.
There is a lever from the outside door lock that goes to the door latch.
There is a lever from the inside locking handle that goes to the door latch, and yet may be one more.
If any of these are "stuck" or broken, they will "hold" the door latch in the locked position.
Be blessed.
Feb 07, 2013 | 1998 Nissan Altima
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Passanger side window won't go down all the way
There may be a child safety device on the latch side of the door you can see when door is opened, which prevents the window from going all the way down. Open the door, and check somewhere near the part that holds the door closed. See if there is a slide lever or button you have to operate to get the window to go all the way down. This is common on many vechicles.
May 09, 2012 | 2007 Hyundai Tiburon
Bonnet stuck down
If the inside latch won't work, you'll have to reach up from underneath the hood to pull the lever over to open. Usually a flatblade screwdriver will help. The latch lever has to move towards driver's side to open.
Nov 24, 2011 | Cars & Trucks
The hood does not lock when it goes down. It
Your safety latch should keep the hood from flying open, but you need to get the latch working. Check and see if the hood release handle is fully in. Sometimes they stick out and keep the latch from engaging. If it is in, then spray some lube on the latch assembly, such as WD-40, and cycle the hood release handle to try to free it up. If this doesnt work, the latch might need replaced.
Apr 19, 2010 | 1996 Geo Prizm
1972 corvette stingray, driver side door does not open fron either inside or outside.
Sounds like the door latch mechanism is worn out.
The door latch mechanism for your door is operated by rods, from the inside door handle, and the outside door handle.
It is highly unlikely, (Though not impossible), that all those two rods have fallen off. (Spring clips hold the rods in place. Opening Rod Control Clip. In the link below they are shown as Item E)
With the window all the way down, carefully use a long flat tip screwdriver, to push down on the lever for the door latch mechanism, to open the door. Make sure the lever for the door lock, in the door latch mechanism, is in the fully unlock position.
This link may help show you the inner door hardware, I'm referring to above,
http://www.mamotorworks.com/corvette-c3-door-hardware+1968+1982-inner-1-106-9491.html
You can see that when you pull out on the inner door handle, it pulls a rod forward. This rod is attached to a Bellcrank. The Bellcrank in turn pulls down on another rod, which pulls down on a small lever in the door latch mechanism, to release the door latch.
When you push down on the outside door handle, it pushes a small rod that is attached to that same lever as the inner door handle. Looking down through the window opening in the door, it is that lever that you're trying to push down, to open the door.
Viewing down through the window opening, try to operate the outside door latch a little. Watch to see what lever it tries to move. That's the lever you have to move Down, with the flat tip screwdriver.
With the door open, it is a matter to check out,
1.The Inside Door Opening Control, (The inside door handle is attached to it), to see if the locking part of it is functioning correctly. Make sure that it goes to the full Unlocked position.
2.The Door Latch Mechanism. Make sure it is functioning correctly. It, along with the various door hardware parts inside the door, needs to be lubricated at specific intervals. The more it's used, the higher the interval rate goes up. (I find that owners seem to Skip this task a lot! I use Lubriplate White Lithium spray)
To replace the door latch mechanism, I suggest you buy a manual for your car, so you can view all of the door hardware to remove, to remove the door panel. Then view how the spring clips come off of the rods, and the three screws come out of the door latch mechanism.
Jul 12, 2009 | 1972 Chevrolet Corvette
Can not open trunk
Sounds like the trunk latch actuator is out.
May 21, 2009 | 2005 Nissan Sentra
Kitchen Appliances - Others Logo
173 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
