Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Phillips 60pp9202.. too much blue
How can i turn the blue down?,,i dont have the manual. the red convergence works ok,,but when i try to adjust the blue,,it dosent really do anything on the (plus sign) convergence icon when trying to adjust it...and what causes halos?,,also how do you check the coolant?
Thanks Dashriprock
    Top Expert:
  • Philips Master
  • 14,553 Answers
1.) As far as the coolant goes--it is clear and called Glycol---you just want to look to make sure you have no leaks---none has gotten on the circuit boards.
2.) If the blue will not move in some direction one of the two STK-392-120 CONVERGENCE chips this set uses is bad. There are also a number of 6.8 ohm light green resistors around them that need to be looked at and tested--The chips are on the left large board side by side on metal heat sinks(as you look from the back)---the resistors are in front and left to right around several plugs(convergence yoke plugs)if any of the resistors are white in the middle they need to be replaced along with both chips.
3.) You can buy the pair of chips on Ebay for about 13 dollars plus shipping--the resistors can be purchased at almost any parts place that sells TV parts--these places may also have the chips but usually charge a lot more then on Ebay.
4.) It all depends on how much soldering skill you have---You will need: Two new chips, Solder, a desoldering braid, liquid flux, heat sink grease, and some denatured alcohol----the flux makes it much more easy to unsolder the chips--lead free solder was used in these sets and it can be difficult to unsolder them---when you solder the new chips in apply liquid flux again.
5.) If you are able to do this repair you can save some real money as most shops TRY to charge 300-400 for this type of repair; I have done hundreds of them and here I charge 200-250 depending on the set.
6.) If you have questions or need advice contact me by replying to this posting.
I do this here for free so if this information has been helpful, take a minute and give me a vote here.
SD TECH
Posted on Sep 09, 2009
Testimonial: "Thanks SD Impressive! sounds like something i can handle.Thank you for the expert advice.how do you vote on here? 4 stars!"
    President:
  • Philips Master
  • 1,779 Answers
You can check the coolant by looking into each of the CRTs ( briefly ) You will see that the Blue and Green are probably in need of replacing of which if you have never done this DO NOT ATTEMPT IT !!!! You will notice the red has a clear image compared to the other two. Fluid change usually costs around $250.00
Testimonial: "yes your right..red is clear, is replaceing the coolant really that difficult? Thanks for your advice"
PHILIPS 60PP9202/17F - Left/Right convergence doesn't work for Red/Green or Blue. Up/Down convergence works OK - What might be the problem?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 17, 2010 | Philips 60PP9202 60" Rear Projection...
I have a Phillips 60PP9202 60in. rear projectiov HDTV, but the red and blue colors are outlining the faces
you need to replace the convergence ic's you can get a convergence kit from.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.tvrepairkits.com/xcart/home.php?partner=larry
techman
Feb 18, 2010 | Philips 60PP9202 60" Rear Projection...
Our phillips 60" TV
Ur convergence is dead.Know how to solders?Must changed the 2 convergence ICS,and all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergencce kit.The shop will cost $300 for parts and labors.
Feb 01, 2010 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 red shadow in the battom of the screen
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Philips 60PP9202 60" Rear Projection...
Replaced both STK392-120 still Blue Convergence problem
Hi, first. thing to do is go into "menu" and keep scrolling down until you get to convergence adjustments see if red & blue move up/down and also left/right, IF they dont you have a bad resistor(s) or open chemical fuse(s), if both colors move, scroll to "factory reset" and try re-setting, let me know the results, hopefully you did NOT.. use generic 120`s, video-tek
Feb 07, 2009 | Philips 60PP9202 60" Rear Projection...
My Philips HDTV 60PP9202 has blue and red curved lines
Check to see if you can adjust the convergence. If you can't adjust the red and blue in all directions you need to replace the convergence chips and resistors. If you not sure how to check the convergence goto the site www.TvRepairKits.com and goto the Tips section.
Dec 25, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips rear projection tv model #60pp9202/17f
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
Menue and multipoint
I fixed this tonight -- it was the convergence amps, which I purchased for $20. Thought it was the convergence board at first but it turned out to be the amps, which commonly fail after 3 years or so.
Dec 17, 2007 | Philips 60PP9202 60" Rear Projection...
Phillips 55in widescreen hdtv
you convergance amp is is shot
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 14, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
183 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
