HDD120/05 frozen after connecting my HDD to usb then open player, on sreen message says device is not connected. on player itself are 4 squares alternating moving about it is set on all tracks with 4 bars of battery
  • Anonymous Apr 30, 2009
    YESSSSSS yes yes thankyou THANKYOU THANKYOU THANKYOU
    I CANN NOT THANKYOU ENOUGH!!!!!!!
    i have had this player for 4 years and it hangs regularly i did not know how to do this - you have just improved my quality of life!
    thaaaaaaaaaaaaaaaaaaaaankyou-
Dear sir.
can you please help me i do have a philips jukebox hdd120/05.
i have been told to day that it is in a hiber mode can you please te me how i can take it out of this hiber mode a remove it so that i can get it to run again .
thank you. peter.
Posted on Sep 08, 2008
Press up arrow and "+"volume button together
Posted on Dec 31, 2007
What usb connector/data cables are compatible with a Phillips Go GEar HDD 1630/17. The usb connector for my Sansa Fuze seemed to fit but when I plugged it into my pc or mac I got a warning message about...
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Apr 10, 2013 | Audio Players & Recorders
Tip
Code?! FORGOT YOUR CODE?!
In order to get rid of the forgotten code and disabled message, we must restore the device.
In this case when the iphone or itouch or similar is giving you a message that its disabled, then we have to first force the device into recovery mode, from which we can do a normal restore.
Note that this removes all the content from your player.
Basically the steps are
1. Take out the usb cable, connect it to the computer, but not to the device.
2. Turn off your device
3. While pressing and holding the home button, reconnect the usb cable to the device, when you reconnect the usb cable the phone or itouch should power on.
If you are low on battery let it charge for a while, then start from thebeginning (unplug the usb from the device)
4. While still holding the home button, until you see a message about "Connect to Itunes" then let go.
5. if not already open, open itunes, you should receive a short warning about recovery mode.
6. do a normal restore from itunes, it wipes the devices and the disabled message and the forgotten code are removed.
on May 01, 2008 | Apple iPod MP3 Player
Ipod 30GB unlocking free code
If you are low on battery let it charge for a while, then start from the beginning (unplug the usb from the device)
Mar 20, 2011 | Apple iPod MA446LL/A MP3 Player
Digital keychain
once you connect the keychain to your computer open MY COMPUTER and it should appear as one of your drives, or you may have to select the USB mode within the keychain itself
Mar 22, 2009 | Innovage Shift3 MP3 Player
Mp3 player not working
mp3 player is showing a flash error message.Please back up the data and format the player.
Aug 29, 2008 | iLO (2 GB) MP3 Player
How do i fix my go gear phillips mp3 player..it froze
Steps to Repair:
  1. Open the Phillips SA-31xx device manager.
  2. Connect the player to the computer while pressing and holding the on/off button of the device (the inner round button.image_thumb%5b1%5d.png). Windows will tell you that a USB device is connected in the repair mode.
  3. The device's screen will look like:
  1. On the device manager, click on the Repair tab.
  2. On Repair tab, click the Repair button. It will show the message that the device is repaired. The device will also show that it's being repaired.
3. After the device has been repaired, below message will be shown.
4. BEWARE ALL DATA WILL BE LOST from the Phillips Go Gear SA-31xx Media Player without any warning.
Aug 19, 2008 | Audio Players & Recorders
Cannot initialise HDD
First of all, of course, try to repair it by using the recovery utility softwear (you know, pressing >> Forward while connecting the switched off device to the usb). If it doesn`t help, read further---> The problem is that simply an error in the softwear of the device occures. Normally, this could be fixed by restarting, by pressing the RESTART button on the back. BUT, by pressing it, you don`t actually restart the hole device.Certain commands are still running in the processor and this cannot be canceled until there is the slightest electricity in the battery left. That`s why I open the player, safely and very carefully remove the Hard Disc, than reattach the battery, so that no electricity is left. Then, connect the battery again, place the HDD again on its place (carefully please), watch out that it connects to the motherboard, and close the hole player.
By switching it on, there should occur no problems. But I recommend using the RECOVERY UTILITY softwear for repairing the hard drive, as well as rebuilding the library and probably formating (hear you will lose all data). Note that it is best to have the song titles written on latein (english), cyrillic for example is not recommended.
If that doesnt fix it follow the steps bellow.
1. Make sure player is off.
2. Take off back cover. 4 tiny screws.
3. Take out the HDD, the big rectangle thing. The back of it should be silver.
4. When you take it out, the front should have a "gold sheet" attached to it.
5. At the lower corner the "gold sheet" is a cut out part. This "cut out" part is where the HDD connects to the "mother board".
6. Bend that piece ever so slightly where u can place your finger between it and the HDD.
7. You will then plug in that "male" part to the "female" part on the mother board.
8. when you feel it snug or snap, your MP3 should work now.
9. turn on the mp3 player to make sure it loads.
10. if it does, then you have fixed your "problem"
11. reassemble player accordingly.
I hope that helps
Please rate accordingly
Thank you
Computerrep
Apr 11, 2008 | Samsung Napster YH-920 MP3 Player
Connection to my computer
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Doodles1
Dec 31, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Iriver 320 HDD Connection
suggestion only, open it up and check the hdd connection. failing that, your hard drive is probly naffed
Sep 01, 2007 | iRiver H340 MP3 Player
Initial fail error
The HDD is disconnected from the player. When you open up the player just carefully push the circut board thing on the gold foil behind the hdd in untill it clicks.
Feb 17, 2007 | Samsung YH-925 MP3 Player
272 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
