I have a xerox docuprint c1618 thats noisy it initializes ok but as soon as it begins to print it makes a noise like a jet engine - very loud. I am thinking it's possibly a fan or the laser scanner assembly. If anyone has a service manual it wou;ld really help. thanks Keith
My xerox Phaser 6130 is noisy and makes light copies. How do I lubricate it? Will this solve the problem?
The 6130 is not designed to be lubricated, but if you feel the need to lubricate gears, then use white lithium grease. I am not sure the nature of your noise. Loud rattling or repeating ticks could indicate damaged gears, and lubrication won't help that.
Often the Image Unit causes noise and bad print quality. Try replacing that first, PN 675K69244.
Whit
Nov 15, 2010 | Xerox 5665 Copier
It makes a loud whining noise when it is on the spin cycle. Functions ok, but sounds like it is a jet engine...
Hello there: Here is a extensive list of things to look at and hopefully this will be very helpful for you Washing machine is noisy It's very difficult to advise on a noisy washing machine because you often can't describe noises accurately enough. People can describe the same noises quite differently. Please visit the following link for a detailed list of ways to help with your noisy washing machine. http://www.washerhelp.co.uk/diy-repair-help_2.html#cl_q4
Dec 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Fuji xerox won't pick up paper for printing.
Managed to get it going ,pulled all the toner cartridge out and reset and all is sweet.....!
Aug 30, 2009 | Xerox DocuPrint 203A Laser Printer
I am sorry, I recently left that job and no longer have the documentation to answer most questions concerning xerox product fault codes.
My apologies, I just no longer have that information.
May 27, 2008 | Office Equipment & Supplies
Xerox DocuPrint N2125
Sounds like the software is corrupted, Sounds like it needs to be updated.
If this link works download and install the Flash Firmware Update
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=N2125&Xlang=en_US&Xcntry=USA&source=XOG
Apr 04, 2008 | Xerox DocuPrint N2125 Laser Printer
Xerox Docuprint C1618 Colour Laser
Are you certain you have typed the right model number? I can't find a Xerox 1618 anywhere. I would love to help.
Mar 24, 2008 | Office Equipment & Supplies
Fuji xerox docuprint c1618 error
001-360 Fan motor failure Check Fan Rear Check Fuser Fan Check voltage on fan rear should be between 15VDC and 24VDC. Check voltage on fuser fan should be 24VDC
Dec 29, 2007 | Office Equipment & Supplies
Not printing from tray 2.
Check that the paper pickup rollers forthat tray are not melted from excessive heat. Take out the paper tray and try to manually move the gears.
Sep 28, 2007 | Xerox DocuPrint N4525DX Printer
k24674
jasbo
jasbo
