Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
Problems starting my hp pf700 tries to start and restart. keeps a black screen. use to work its way through this and check for error and resume to function prior to error. but now does nothing. will not even come on. I dont recall a recovery disk coming with my laptop. Not too sure what to do.
  • Nike Merritt May 11, 2010
    You can order a recovery disk from compaq cheap, less than $10. just go to compaq.com. and look for support for your model
  • 674 Answers
Re program first the systme.. maybe the problem only is program.. if during the installation you did not meet any problem it means the problem is software only.. because if the problem hardware it cames during installation or after the installation it will come again
Posted on Sep 10, 2009
Screen say resuming windows
Try to start your laptop in safe mode
if you able to start in safe mode then Update drivers for your hardware from the site of your laptop manufacturer(in the support section) .Most black screen are hardware or driver related so updated drivers could fix the cause of the STOP error.
-Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues,
-If this didn't help you then simply get the Intel software partner Reginout to fix all the errors which black screen
Jun 17, 2013 | HP Computers & Internet
How do i get setup is starting services off and open windows
I found a solution for the same problem that fixed it for a few people. Try this:
1) On the same error screen press SHIFT+F10 and it will open up a black Window. (a command prompt window) 2) In the black windows type the word "regedit"(without the inverted commas and hit enter. That will open the registry editor. In the Registry Editor.. Browse to.... HKLocal machine/SYSTEM/SETUP/STATUS/ChildCompletion, and after highliting childcompletion,on the right hand side check for setup.exe. if the value is 1 change it to 3.(by double clicking on setup.exe and changing the value shown in the box). Then close the registry editor and then also close the black window. Then click on OK for the error and the computer will restart and the installation may complete. just try it and let me know if it worked.
I found this solution at http://www.tomshardware.com/forum/69394-35-acer-aspire-wont-setup-starting-services-help
Let me know if this helps,
Thanks!
Apr 05, 2013 | Acer Aspire Computers & Internet
Hp laserjet 9050n appear disk not initialized .how to solve. thank you.
Turn off printer
Press and hold PAUSE/RESUME(START on MFP)
Turn on printer
Keep holding the PAUSE/RESUME or START until all 3 error lights light
Release the buttons
Press LEFT ARROW(5 button on MFP) until INITIALIZE DISKS appear
Press the CHECK(6 button on MFP)
Wait for printer to READY
May 11, 2011 | HP LaserJet 9050 Printer
Hi!!! I have an hp compaq cq 40 laptop.Frm sm days a problem persists wid it.whn its running normally ,all of a sudden its screen goes black...widin 1-2 mins its automatically shut down.Whn i restart it...
Check in the power options area of your operating system, and switch off hibernate and switch off sleep, this should prevent the machine powering down.
May 06, 2011 | Dell OptiPlex GX280 PC Desktop
Do not start up, black screen
I'll asume something for this one it might help. Make sure your laptop is completely turned off [No fans turn, screen black, no hard drive light]. When you then press the power button, immediately keep pressing the F8 button on your keyboard. It should then actually display two options after a while :
*Delete restore/resume point and start windows
*Resume restore/resume point
Select 'Delete restore point' and the unit should boot up fine again.
I had a unit that was basically turbo-booting into windows, but the restore point was corrupt and it always seemed it had a 'blank screen' problem.
You can also try to access the BIOS by pressing F2 as soon as the unit starts up to see if you can actually access the BIOS.
If that all doesn't help I suggest reseating RAM.
May 23, 2010 | Acer Aspire 9800 Notebook
Paper jam in hp laserjet 1010
Error 600
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 28, 2010 | HP LaserJet 1010 Printer
Stop Error Vista Blue Screen
HI,
To determine what is causing the issue just restart the pc and keep pressing f8 key - this will take you to advanced boot meny.
First of all login to safe mode and check if problem persists there - if no go to start and in start search bar type in MSCONFIG - then hit enter.
After that go to startyp tab in system configuration window and click on disable all startup items.
Restart yuor pc in normal mode and if problem will not persist keep enabling startup items one by one. This will allow you to determine which software is cauusing the problems. Then update that software. Unless it is really old it should work with vista.If that is xp only software you will be able to use that in Windows7 under xp mode. Check Mocrosoft website for more info on XP mode.
BR
SRG
Oct 26, 2009 | HP Pavilion Desktop with AMD Phenom X4...
Check Printer and Press resume key message along with Alarm light
Too many things can cause that, paper jams, carriage errors, printhead problems, purge assembly errors, feed roller errors, need more info to be of any help.
Aug 12, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Laptop keeps restarting infinitely with black screen
This article explains how to disable the restart on failure so you can see the stop error code that will help you diagnose the problem. (see here and here.
Here is the HP home support page for your system, with articles to help you troubleshoot here and here., or here.
If you get windows started again, I recommend you run chkdsk to check your hard drive for corruption (instructions here and here), and run a scan for malware by following these protocols,(at least first 4 steps) before you reboot. That will establish a baseline against which you can troubleshoot other causes...
It would also be wise to examine your event viewer and see what sort of errors or warnings are reported there, to know what you're up against...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 29, 2009 | HP Pavilion dv6000z Notebook
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
250 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
