Re: Samsung lcd tv mod.# LN-S 4051D\r\nNo power.
Re: Samsung lcd tv mod.# LN-S 4051D No power.
I opened up power supply, and replaced four bulging capacitors 10v, 1000uF.
Now when I power it up, red indicator light blinks 4 times, and I still have no power.
Any solutions?
  • jiro Sep 10, 2009
    Samsung Ln-s4051d, no power, I replaced 4 bulging copacitors 10v 1000uF. Now led blinks 4 times still no power.
  • jiro Sep 17, 2009
    Thanks for the helpful tip.
  • 555 Answers
First, check for short circuits. More likely that a semiconductor ( let's say a power transistor or diode) is acting like a conductor.
Also, check the inverter board, the part that lights the tube in the display. It may have a short circuit.
Transistors and diodes are easy to determine if it have a short circuit or if it's open, there is no need to remove the part, but be sure to discharge the capacitor before checking.
Good luck.
Posted on Sep 10, 2009
  • 1,906 Answers
Check and, replace your D1,D2.etc. diodes
if you have a scope look for the transitional waveforms converting from AC to DC power. this is usually accomplished by a transformer T1 that bridges the two voltages. the set will either use a rectangular block with 4 wires going to the board that has a corner sliced off (12 volt full wave rectifier) or, four diodes to convert the ac (wall)voltage to dc (tv) voltage
Posted on Sep 09, 2009
TV takes a long time to come on, then after a while, it starts turning on and off.
This LCD might have a defective power supply. I would suggest to open the back cover and inspect the power supply for swelling/bulging capacitors that are located near CN801.
Check the following link to find the power supply: http://www.shopjimmy.com/samsung-bn44-00184a-power-supply-unit.htm
Aug 28, 2015 | Samsung LN-T5271F 52 in. LCD Television
Samsung television problems
Check the power supply to see if you have any bulged capacitors. If so, then you should be able to just replace the capacitors. If not, replace the power supply.
Feb 06, 2014 | Samsung LN-S4692D 46 in. LCD HDTV
What is large capacitor on Samsung LN-4051D
If its in the power supply its the input filter--usually 600 uf or more at 180 volts or more----flattens the ac coming in to remove ripple from the voltage so as clean a DC voltage as possible---is it buldged or puffed up on top or what?
Apr 07, 2012 | Samsung LN-S4051D 40 in. LCD Television
Describe your LN-T4671F 46 in. LCD Television Problem When I turn the power on, the TV clicks on and off several times before it finally powers up and the screen comes on. Is this a common problem, and if...
Good day!! That problem is usually cause of bad/faulty capacitors on the power supply board..So you have a better chances and easily locating the faulty capacitors if it is look like leak/bulged on the top.. So please try to follow this instruction on how to do that.. 1. Open the back cover of your TV. 2. Look at the power supply board..Its normally connected to the power cord.. 3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors.. 4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value.. 5. Some of the capacitors not bulged so its better if have a capacitance meter.. Hope it helps you..
Sep 13, 2011 | Samsung LN-T4671F 46 in. LCD Television
I have a Samsung LN-T4671F 46 in. LCD Television and once it is on, it works great. The problem is it can take up to 15 minutes to light up after hitting the on button. A series of clicks can be heard...
Tv power supply board have problems.That the board,where the power a/c cord plug into it.U have all the tools,can do basic soldering and understanding basic electronic?Tv have dying parts call capacitors on the power supply board,searches these dying capacitors,it all way bulges or puffing up on it tops.Repaced all these dying capacitors soon to dead capacitors,that are bulges or puffing up on it tops.Will solved this delaying and clicking sounds and power up quickly.Or tries websties like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 11, 2010 | Samsung LN-T4671F 46 in. LCD Television
The power button clicks continuously and no longer works to turn the tv on
You can open the TV and inspect the power supply for bulging or leaky capacitors near CN801.
The power supply is failing due to defective capacitors.
If you need the power supply to swap it, check here for parts.
Let me know if you require further assistance.
Aug 14, 2010 | Samsung LN-T4042H 40 in. LCD HDTV
TV TAKES A LONG TIME TO TURN ON
The tv power supply board have those dead parts call capacitors,they alway have capacitors leakages of gases,bulges ups on it tops or puff up on it tops.These capacitors are having leaking gases and dying reqiure changing,u know basic's electronic and soldering.Replaced these dying capacitors soon to dead capacitors,ur tv will power up normally and work quickly.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jul 10, 2010 | Samsung LN-T4665F 46 in. LCD Television
My Samsung LN-t4671F LCD TV clicks for about two
You are having another problem with the power board...there are some capacitors which are easily replaced to cave you the cost of the board. If you are technical,I can guide you further,other wise a reputable shop can fix this very reasonably
Jun 07, 2010 | Samsung LN-T4665F 46 in. LCD Television
Samsung lcd 40 will not come on. red blinking light. how can I fix
Power supply board is dead,Know how to solders?Replaced these capacitors that puff bulge up or burst open.Might get power back,because somethings else
might be also dead need it replaced.Tries websites Shopjimmmy.com,Ebay.com to buy a refurbish power supply board to replaced,if have no Tech.skills
Feb 04, 2010 | Samsung LN-T4665F 46 in. LCD Television
Samsung LNS 4051D color problems
1.T-con board or related cables problem -- 60%
2.replace Main Board -- 40%
Jan 25, 2009 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
Electro Med Services...
