Question about Freezers
Walk in freezer placed inside a room, condensate problems
Our walk in freezer is inside a room about 4 inches clearance all around. Condensate is driping onto the floor and running into adjoining spaces. Should we open up the space to air or fill it with expanding foam?? or any other ideas.
  • peter_scotla Sep 09, 2009
    the walk in freezer has an external mounted compressor, so the condensate is only from wall condensation??
    thanks
  • 415 Answers
No don't do that sounds like the drain tube going to the defrost pan is not in properly remove front grate and inspect to see if tube is off to one side if you completely seal the void that is required on operating frig's if has no air flow to cool the compressor will overheat and shorten the life or not cool properly
Posted on Sep 09, 2009
Frigidaire mod.#affu2067ew2. Gasket snug and clean. Exterior door is very cold alot of condensate. Gasket is dry but door is wet.
sounds most likely didn't get a good fill in the foaming machine the fills the door cavities wiht insulation. I've been in a refigerator plant and seen it happen. They are supposed to be checked. Tap various places around the outside of the door to see if there is a hollow sound. It could just be around the outside edges of the door unless the whole door is cold.
Nov 18, 2013 | Frigidaire Freezers
I have a Haier chest freezer model HCF208A that is always wet on the bottom. I have it well clear of all walls and a nearby washing machine but it drips so much that the timber flooring is in danger of...
Great question.
Before i can access the issue I need to ask if you have a humidity gauge in your home?
You need to check the overall moisture content in your home. Because Freezers and refrigerators create a lot of heat and have to condensate moisture they will have some water that should be evaporated by the pan under or on top of the compressor.
However, if you home has a high humidity, which may not be noticed by yourself, Freezers will condensate a large mount of water. If the freezer is in the basement or near another warm source like a furnace, hot water heater or washing machine it may make more moisture.
So check the humidity levels around your freezer for at least one week. Check it in the morning and afternoon after work lets say.
The humidity should be between 30-50%. If it is higher than this I would suggest a dehumidifier. High humidity in a house can cause wood damage , mold and other issues like excessive moisture on a freezer or older fridges.
If you find that the humidity levels are within range I might suggest that you use a small fan to circulate air around the area the freezer is in. The only other option is to replace the freezer with a new model the reduces exterior moisture.
I hope that his helps you in getting this issue resolved!
Oct 14, 2013 | Freezers
On the ceiling in the walk-in freezer drops of water frozen around the area by the fans
That tells me that when the evaporator defrost the water condensate is not draining to the outside of your freezer. You will need to find the drain blockage, Thanks Sea Breeze
Feb 27, 2013 | Kolpak Commercial Freezer
Exterior door presents condensation (a vertical line in the middle)
Normally when there is insufficient air flow in the room the freezer door will condensate and show wet spots.Have that often when testing a fridge in the workshop. Once the door is wide open, the wetness on the door goes away.
Dec 14, 2012 | Whirlpool 19.6 cu. ft. Upright Freezer...
My kenmore chest freezer is the garage, the temperature outside is over 30 celsius, the side of the freezer where the motor is is very hot, and some other places on the front and other side is warm to the...
The hot sides is normal, this is how they expel the heat from inside the freezer, sometimes it may help to use a fan to help cool. Also make sure there is about 12" of room around all sides of the freezer .
Aug 22, 2017 | Kenmore 14.8 cu. ft. / 419 liter Chest...
The refrigerator has two halves. One is the freezer side and the other refrigerator Water is leaking from the freezer side. Appears to be a problem with the defroster. I do not have the model #
One of two things is happening, there is a heater inside your condensate line that prevents the water from freezing, this may no be working. You can check this with an amp meter if you have one. Or your condensate line is clogged with sludge which would cause the water to not drain and freeze. You will need to take the drain apart to defrost the ice and blow out your line.
Sep 16, 2011 | Continental Freezer Wide...
I keep my freezer in my garage, and It is warm out there, but I've noticed that the sides of my freezer is very warm to touch,on sides is this natural. it has been a very good freezer, and is almost 20 yrs...
Most units now use condenser coils hidden inside the walls of the unit verses exposed in the back. If your unit does not have exposed coils or a forced air cooled condenser then they are most likely in the walls which would make what you are describing completely normal. Just make sure you allow 3 to 4 inches of room around them to let the system cool itself.
Jul 08, 2010 | Kenmore Freezers
Defrosted a Crosley freezer, have water draining from door
ITS RARE BUT NOT UNUSUAL,its only condensate from the surrounding room collecting inside a cold door frame,if you dont defrost it at least twice a year,you will loose efficiency.
Jul 05, 2010 | Freezers
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Vulcan freezer has condensate coming thru freezer wall and thru
no epoxy is not enough
you need to insulate the floor use sheet unsulation it comes in 4x8 and then sheet over it with ply wood like a 5/8 ply seal arround the edges with a good indoor our door silicone then use epoxy th seal the ply
by simply sealing the floor you will get loss and make your pump work 3-4 times as hard using 3-4 times the hydro witch means more money over the long haul
spend some time and cash now or spend a lot of cash later.
Jul 23, 2009 | Freezers
Freezers Logo
132 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
