Question about Optoma EP1690 DLP Projector
After being on for a while sometimes 10 minutes, smoetimes 2 hours, the projection loses color and flickers, I can hear a squeeling noise, and eventually shuts down
    Problem Solver:
  • 4 Answers
Mine does the exact same thing, but usually before it overheats and shuts off. This started after I replaced the lamp the third time. I haven't found an outside solution to this, but pointing a floor fan at it to keep it cooler works for me. Did you ever find a resolution?
Posted on Dec 18, 2010
I have an RCA 52"
Your convergence has failed and needs to be repaired. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 31, 2011 | RCA HD52W59 HDTV Projection Television
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
Tv stays on for couple of minutes and then shuts off
Hear any grinding or motor noises,pictures flashes or flickers in black and white?All these cause are the death of a colors wheel.Must replaced the colors wheel.When was the last time,this tv replaced it projection lamp?1 1/2 or 2 years the projection lamp was replaced,tv on and in used like 4 or 5 hours a day.The projection lamp life is over.Require a new projection lamp.
Aug 16, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
62" RCA dlp loses color
If you hear any winding, whirling or screeching noise (Color Wheel symptoms)
If there is any vibrations in the TV (Color Wheel symptoms) you would need to change the color wheel.
Apr 15, 2010 | RCA HD61LPW165 61" Projection HDTV
My KP53V45 has sound and a very faint picture all in green with a number of horizontal lines. It also shuts down after 10 to 15 seconds. Is this a projection lamp issue?
Sounds more like a color wheel, if the color wheel is not working properly the on board computer will shut her down. And will get weird colors or flickering colors.
Sometimes will also make noise.
Mar 13, 2010 | Sony KP-53V45 53" Rear Projection...
I try to start the tv and all I hear is a slight squeeling noise, think it is the color wheel. I just bought a new lamp. the tv makes the noise it initially makes telling me it is trying to start but two...
If you hear a squeeling noise, then that would be your color wheel. When you replaced the lamp, did you reset the lamp hours? Did you check the power from ballast with a voltmeter to see if you are getting power to the lamp?
Feb 06, 2010 | Samsung Remote Control
Temporary losing picture
CHCK THE OPTIONS MENU SEE IF IT HAS A COLOR CONVERSION OPTION ,,TRY THAT,,ALLIGN THE COLORS
May 14, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Missing Color.
the color wheel may spin but if you hear noise when it spins it's bad. the jumper is used when replacing one type of color wheel for a nother type. so donot remove jumper unless you've replaced the color wheel and the picture is bad. if the color wheel is good replace the DMD board. if the DMD is not available replace the optical engine.
Jan 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Losing picture color on TV
Screen flicker can also be a bad dynamic black unit. Do you hear a low pitch growl when it flickers?
Dec 30, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Optoma EP1690 DLP Projector Logo
386 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
