Question about Vizio L32 32 in. LCD HDTV
WILL NOT TURN ON.NO LIGHT ,NOTHING - Vizio L32 32 in. LCD HDTV
  • karlbillek Sep 09, 2009
    The fuse is fine.I thought I would be able to elaborate after paying.
    Thanks for your help.Karl
  • 10,515 Answers
The manufacture recommends that there are no user serviceable parts inside. This is due to high voltage being present even with the TV unplugged. If the red light is lit or flashing the problem will not likely be a defective fuse. If no light is lit it is possible the problem is a open fuse. The fuse will be located near where the power cord is connected to the chassis. Replace the fuse if found to be open with a fuse of exact value. Your local Radio Shack will likely have the fuse if needed. Use a small TV repair shop. They depend on word of mouth advertising to say in business . If they overcharge the customer or charge for unneeded parts they normally do not stay in business very long. You can check with your local BBB to see if the shop has any complaints that they have not satisfied the customer.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 09, 2009
  • taran_2005
    taran_2005 Sep 09, 2009
    Thanks for your response!!
    As you have checked the Fuse, more likely it's an issue with Power Failure.
    From your description the problem seems to have occurred with the power supply. Most likely it seems that the power supply has failed. There might be a faulty capacitor
    or bad fuses resulting in burnt off resistors and transistors. There
    might be bad ICs and diodes. So the PSU also needs to be checked. I
    rather suspect bad ICs and Diodes in the PSU. But you will have to
    check for bad caps and other components too.
    If you want to repair it yourself then you should be having proper knowledge about the internal circuitry of the TV.
    You should also require a multimeter and soldering equipments and schematics.
    If you wish to take it to a repair shop would you like to have an idea of the cost of repair?
    If you have any other queries then I would be glad to assist you further.
    Thanks.
Why does light comes on turntable turns when door opens nothing lights on display or nothing works ?
Normally faulty micro switch which needs replacing: Caution: hight voltage may be present so best left to service person
Jul 23, 2014 | Oster Microwave Ovens
Not starting, lights and dash lights will turn on but when u turn it over nothing
Battery is corroded, clean it and charge your Battery... Then see what happens...
A dead battery will not start a car
Apr 14, 2013 | 2001 Buick LeSabre
IGNITION KEY TURNS ON BUT NOTHING WORKS
sounds like a bad battery or bad cables go to battery(corrosion or just loose]
Mar 26, 2013 | Cars & Trucks
93 infinity j30 wont start
CHeck for loose/bad connection at battery and starter.
Jul 19, 2012 | Cars & Trucks
RED LIGHT FLASHING NOTHING ELSE WORKS
Red light flash slowly but bright and nothing more, can't turn it on, won't light up. What must I do?
Jul 25, 2009 | RIM Blackberry 8110 Cellular Phone
1987 F150 302 ci. EFI, Automatic, Was running good. Next morning NOTHING! Wouldn't start or crank over? Just clicking and buzzing, Headlights OKAY. Tried jump starting... NO GOOD. Took battery in... Was...
try over riding the starter relay on the fender ,it has one there right?. dont go to a mechanic yet. the engine aint seized. if it doesnt have this relay then i would get the alternator tested. if you want to test it yourself it can be costly for the right equip. autozone usually tests for free. i dont know were you live so if theres not an autozone. let me know if you cant get it tested.
Feb 22, 2009 | 1987 Ford F 150
Alero Interior Lights Will Not Turn Off
a bad control module.it controls inside lights and door locks.
Sep 03, 2008 | 1999 Oldsmobile Alero
Vizio L32 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
