This is more than likely your laser that is dead or dying and its possibly a samsung or hitatchi drive, be
careful when buying a new laser because there is a lot of dodgy ones around at the minute which can damage
your machine or at the very least will be inferior and not last long.
It could also be the logic board or the drive belt too, if the logic board is faulty no matter how many lasers
you try it will do the same, the fix is to replace the logic board.
if its the drive belt well this is very easy to try and is what id try first, open your 360 tray and look
inside the 360 you should be able to see the drive belt, make sure its attached properly and then take this
out. replace it with a new one and see if this recifies your problems.
SOMETIMES if a drive belt is stretched it will not close properly and then a fault like yours will occur. its
all a matter of eliminations. Drive belts can be found on ebay.
there is a XBOX 360
repair guide available that covers this problem and also all other common XBOX
problems. You can get your copy XBOX 360 Repair Guide, you can download it and
get help to fix your console. click here to download repair guide
While Xbox 360 is a popular video game console for many game lovers, Microsoft also provides large space up to 250GB for making Xbox 360 more than a video game console. Most users many take Xbox 360 and a part of the home entertainment with the Xbox Live Marketplace and home movie collections. <br /><br />Xbox 360 Supports video files in Windows Media Video (WMV) format, ASP, H.264 and MPEG-4 media in .mp4 format. If you downloaded MKV videos from hd-torrents.org, you need to convert the <b>HD MKV videos to Xbox 360 WMV</b> before playing them. Aunsoft Video Converter is the best HD <b><a href="http://www.aunsoft.com/video-converter/">MKV to Xbox 360 Conversion</a></b> on Windows to make it easy to play WMV on Xbox 360 via DLNA. <br /> <br />Follow the step-by-step guide below to <b><a href="http://www.aunsoft.com/top-notch_hd-torrents_mkv_to_wmv_converter_for_xbox_360_with_dlna/">Convert and Share MKV to WMV files on Xbox 360 via DLNA</a></b>. <br /><br />Step 1. Load MKV to Aunsoft Video Converter. <br />After downloading MKV from torrent sites, just run Aunsoft Video Converter as the best MKV to Xbox 360 converter, and click the "Add" button to import batch of .mkv videos. <br /><br />Step 2. Choose Xbox 360 WMV format. <br />Click the "Format" option and choose <b>Zune/Xbox 360 Device > Xbox 360 HD Video(*.wmv)</b> as output format. The Xbox 360 video converter will convert MKV to WMV for perfect playback on Xbox 360. <br /> <br />Step 3. <b>Convert MKV to WMV for Xbox 360</b>. <br />Click the convert button under the preview window, and the MKV to Xbox 360 converter will start converting MKV torrent videos to WMV for playing on Xbox 360. <br /><br />You can easily <b><a href="http://sony-mts-converter.com/2011/07/xbox-360-dlna-convert-and-play-mkv-to-wmv-files-on-xbox-360-via-dlna/">Play the WMV Files on Xbox 360 via DLNA</a></b> after copying the video files to Xbox 360 and <b>Watch Videos on DLNA-compatible HDTV via network</b>. <br /><br /><b>Tips:</b> <br />For playing Blu-ray disc movies on Xbox 360, you can use <b>Aunsoft <a href="http://www.aunsoft.com/blu-ray-video-converter-ultimate/">Blu-ray Video Converter Ultimate</a></b> to rip and convert BD movies to WMV for Xbox 360.
To listen to music files encoded in Apple's AAC audio format, your Xbox
360 console will need the AAC codec (a processing file), which is
available as a free download from Xbox LIVE Marketplace.
A drive that will play DVD movies but not Xbox 360 game discs has been
set up incorrectly at the factory. The only solution is to return the
Xbox 360 and specifically note the problem so the drive can be repaired
or replaced.
The problem you are facing is of a copied Xbox 360 game you are probably trying to play on a Genuine Xbox 360, these discs are read as a movie disk and it shows as "Play DVD".
When you try to play such discs, it would give you dvd media control bar on the bottom and the message in chinese letters is actually a message asking you to insert this disc in a Xbox 360, which is actually a Modded Xbox 360 that is required
