Question about Sony Televison & Video
Every tme the channel is swiched to an HD channel, the picture is not displayed in full-screen. How can I get the picture o be shown in full-screen at all times?
  • 784 Answers
Under Screen setting, at Wide mode you can select Full to take care of this problem.
Posted on Sep 09, 2009
Don't know how to make the picture in my sceptre Komodo 42 inch stretch full screen
Picture shown is in 4x3 aspect ratio---try different channels to see if any are full screen or 16x9----set should have a aspect button on the remote but be aware if using a box or even not many programs are formatted for the 4x3 which in this case has black side bars----if left for a very long time in that format those can burn the image into the actual display screen.
Nov 05, 2012 | Televison & Video
Is the integral Freeview on my 32 inch Full HD TV HD or Not
Simple answer. No. But please read on . . .
Full HD Freeview, i.e 1080p does not exist. The four HD channels currently available on Freeview all transmit at 720p resolution. There is insufficient bandwidth in the TV transmission range for the HD channels to transmit at 1080p. It could be done, but it would be at the expense of other channels.
Your TV, however, is Full HD, as indicated by the 1080p in the specifications. This means it can display a full HD picture from a device which outputs at 1080p resolution. Devices which generally output at 1080p resolution include Blu-ray DVD players, games systems and PCs.
When viewing a Freeview HD channel, your TV will display the picture in 1080i (interlace) resolution. This is not true/full HD. The transmitted picture comprises of 720 horizontal lines and the software inside the TV is creating the additional 360 lines and interlacing them between the 720 lines from the original transmission in order to create a 1080 line picture which fills the entire screen.This process is commonly known as 'upscaling' and can cause deterioration in the overall picture quality, most noticably on poor quality, cheap TVs.
Hope that explains it for you sufficiently!
Nov 10, 2011 | Televison & Video
On some HD channels that do not go to the full screen the top of the screen is not filled with a picture
That is a problem with all HD service, not all the content on HD channels is infact HD so it doesn't fill the screen. Only thing you can do it zoom the picture in or put up with it.
I think its almost criminal that cable and sat companies charge us for HD channel and don't play all HD content. But such is life.
Cheers,
Jan 06, 2010 | Panasonic Televison & Video
Can't get full screen
I have a Vizio. If I use the HDMI input I can only get normal and zoom w/ picture buttom on the remote but get full picture on all cable supplied HD channels but not on none HD channels. However, if I switch cable input, I have the TV set up with both inputs from the converter box, I am able to have the options of normal,panoramic,wide and zoom on all non HD channels. I don;t like the black bars top and bottom of the HD channels with this imput mode so I switch back to HDMI. Maybe your TV is simmilar.
Jun 28, 2009 | RCA L32WD22 32 in. LCD HDTV
Someone was messing around with our settings yesterday and now the picture is not full screen. How can we get the picture to fill the screen?
i was going crazy then i finally found a clue on google: hit the setting button on your digital cable remote, go into 'display', change aspect ratio to 16:9, screen size to 'stretch', and output to 1080 or 720 depending on what you have. Were HD channels full screen? If they were they were NOT set properly as above anyway and non-hd channels were black on both side with some having black all the way around on some channels, correct? Hope it helps! I have time warner digital cable and an 52 LG 70 with HDMI...no settings on your tv will fix this if you are in a similar situation b/c its the settting in the digital cable box that need to be re-adjusted.
Nov 28, 2008 | Televison & Video
Red and green
It might have HD set on if you dont have HD on TV
the swich to do no HD is on the cable that hooks up 360 to to
Sep 23, 2008 | Video Game Consoles & Games
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Picture issues
Greetings caesar975,
Unfortunately if you chose to view the non HD channels in wide screen format, you are going to have the top and bottom of the screen cut off. Eventually this will not be a problem when everything goes to digital. However presently non HD channels are presented in 3:2 ratio where as HD is 16:9, So your choice really is to view them with the lines on either side for now.
I do not have an answer for the white flickering lines.
To get the BEST picture out of your 1080p unit I highly recommend using HDMI cables to hook it up.
I hope some of this helps.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 11, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
May 21, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
