Question about Car Audio & Video
I have a Rosen Necvox RE8269D car DVD player. When I insert a disc nothing happens. It used to start spinning when a disc was put in, now nothing. No spinning, no picture, no sound. Thanks Lisa.
  • patersonnz Sep 10, 2009
    Wires are fine, and all fuses are fine.
    President:
  • 1,884 Answers
Lisa, check its connections. Does it poweron when you insert a CD or when you press its power switch.
Posted on Sep 10, 2009
  • 854 Answers
It seems this an issue of power source. Have a technician check the wiring. High possibilty that there is no power or might be low power output.
Posted on Sep 09, 2009
My necvox re-1569 screen does not turn on what should I do
My husban had to unscrew the whole DVD player and found that one red wire was loose, he did weld it and it worked again.
Jul 03, 2011 | Rosen NECVOX RE1569D Car DVD Player
My Necvox RE8269D will start to load a disk, then after about 20 seconds says "No Disk". It does work on some disks
Dust is a killer to anything that uses a laser to read information, eg... CD's DVD's etc etc. we get at least 3-4 people coming in to the shop a week that have problems with units failing to read CD's. The only thing that you can do with out pulling apart the unit (which can get very complicated) is to use a lens cleaner CD/DVD. you can buy on specificlly made for units that "****" CD's in, or for lid types. i would suggest getting the appropriate one for your needs and running that through a couple of times. afterwards, remove any dust off where the DVD/CD inserts, to stop it carrying it in to the lens. If that doesnt work then you may have to take it to a specialist where they will check for loose connections etc.etc...
I hope this has helped you and please dont forget to rate my solution.
cheers
Jan 15, 2011 | Rosen Necvox RE8269D Car DVD Player
Dvd player hangs up while playing
Sir I dont think its the dvd that is not working I thisnk its the screen that is starting to fail, it can be that the dvd is not sending the video signal to the screen when you open it and thatt is why you only get the blue screen and nothing else, because if the dvd was not working let it be the laser or a motor the most common message that you get in the screen is no disc, but that is not your case so I would have the screen check on that portable dvd.
Jul 23, 2010 | Rosen CV8081D Portable DVD Player
Necvox hq3 does not play music cd and mp3
the dvd player tells me that the dvd is invalid . took it 2 best buy & they told me i need 2 reprogram it but i have no disc .want 2 know if this would solve my problem & where could i purchase a disc
Oct 05, 2008 | Delphi MV10021 Car DVD Player
Insignia roof mount DVD player for car wont read disc
My Necvox RE9269 Dvd Player Starts And Then Stops In A Moment Then Displays The Message 'NO DISC' Can Anyone Help Please
May 13, 2008 | Car Audio & Video
NECVOX RE-8169DVD ' No Disc' Error Message
Hi
I think you can see the lens of the DVD's laser.  If so get some glass cleaner, and a Q-tip.  Dampen one tip of the Q-tip with the glass cleaner and clean the laser lens.  Use the dry end of the Q-tip to dry the lens
Oct 31, 2007 | Necvox RE-8169D 8 All-In-One Motorized...
Open message when closed/disc wont spin
I figured it out, it was the little plastic sensor stick that tells the unit that the lid is closed therefore reading the disc. cheap piece of plastic that has surely snapped on many a unit. good luck replacing it. i rigged it though problem solved
Sep 16, 2007 | Necvox RE-8169D 8 All-In-One Motorized...
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
