Question about Cooktops
Need help to unlock the cooktop
I have a wolf 36 inche electric cooktop that I bought from a private seller on the net and had it professionally installed.
The lock key is on ( this cooktop has the safety feature ) This will not unlock. what could be wrong.
  • 2 more comments
  • Naeemk Dec 10, 2007
    How could the problem in the circuit board be fixed. I have had a service tech look at it - Unfortunately there is no serial number on the cooktop The model is CT 36ES.
    Can an electrician fix this - what part do I need to order as it will be out of warranty work
    Thank you for your reply Mike. It is a 36 inch electric cooktop -wolf has only one type as I understand. My concern is the same re serial number / model number missing. According to seller it was a display model. The seller had advertised that it was six months old and only on display for 2 weeks and never used otherwise. He sent pictures prior to my buying that showed the elements working. The model number on wolf site is. Manufacturer Model: CT36EU as seen on the wolf web site. It has a wolf service number at the bottom to call and everything looks good. The professional installer thought that the cooktop looked fine and does in all aspects look genuine except for the missing numbers.
    Hope you can help solve this.
    Naeem K
    Here is the picture of the cooktop v
    Here is a picture - seller tells me he bought it from L& M appliance - North ave chicago ???
  • 290 Answers
You will have to hold the lock button down for 3 or 5 seconds for it to unlock. If this doesn't help, it could be a stuck key pad or a problem in the circuit board.
Thanks/Mike
Posted on Dec 10, 2007
  • Michael  Lindley
    Michael Lindley Dec 10, 2007
    Because of agreement Wolf has with their distributers, they don't offer parts online. You will need to contact a dealer for parts.
    You can find the closest dealer to you here
    http://www.wolfappliance.com/constantcar...
    The electrician should be able to repair it if he is willing to do it.
    I am concerned about it not having a serial number. This is unusual if it is a genuine Wolf range. Most of the time that an appliance is missing the serial number it is because it was never supposed to be sold for some reason.
    I am having trouble finding the model number anywhere in my database. Please tell me exactly what type of range it is. Gas, Electric, Duel Fuel?
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Dec 13, 2007
    Have you located a Wolf dealer near you that will order a control board for you? There might possibly be a parts diagram inside the cooktop once you get it apart.
    Mike
I have a Wolf cooktop model CT36E/S that has the burner lock key flashing. I tried shutting off the breaker many times. PLEASE HELP!!!! Model. CT 36 E/T Serial 11040943
way late but if not fixed here ya go...
Look in the bottom right corner of your Wolf cooktop. A key symbol glows when the cooktop is locked. Press and hold the glowing key symbol for three seconds. The cooktop emits three chimes and the symbol stops glowing when the lock is switched off.Hold the key symbol down for a further three seconds to reactivate the lock.
Jan 20, 2018 | Cooktops
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
We can't turn off the igniter on our gas cook top
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Mar 27, 2011 | Wolf Range RHP-6-36 12 in. Gas Cooktop
Wolf Induction cooktop is locked in Showroom mode
If Shr (5hr) appears on the display then the cooktop is in showroom mode. To exit showroom mode the cooktop must be locked by pressing and holding the key symbol for 5 seconds. After the cooktop is locked, press and hold the melt touch pad for 5 seconds.
May 01, 2010 | LG 30" Built-In Electric Induction Cooktop...
Wolf cooktop 5HR light keeps turning on. Pressing
Turn off power to the cooktop (i.e., using circuit breaker if needed) for 15-20 minutes. Once turned power back on, problem disappeared for me. The semiconductor needed to be reset
Oct 21, 2009 | Bosch 24 in. PIE675T01E Electric Cooktop
30" wolf induction cooktop and it is locked in showroom mode
Hiya, hold the child lock button for 3 seconds. should unlock. Best of luck
Jul 12, 2009 | LG 30" Built-In Electric Induction Cooktop...
My electronic ignition on gas Wolf cooktop(30 inch) isn't working on any of the burners. Why?
Is the ignition battery or mains electric? If it's battery,check the battery isn't flat. If it isn't it will be the ignition unit.
If it's mains electric it's more than likely going to be the electronic ignition unit.It is quite a fiddly job to change/test this. I would highly recommend getting a qualified 'Gas Safe' engineer to check it out.
I hope this helps.
Jul 08, 2009 | Cooktops
Wolf electric cooktop
This is what Sub-Zero has to say (sounds like techno-gibberish)
Looks like it's technician time -
CT Induction Cooktop Error Code E13
Jan 04, 2018 | Cooktops
Cooktop shut off and lock itself up
36" electric wolf brand cooktop. Goes off completely after just few seconds sometimes 30 sec. sometimes minute..Repair man looked at it-thinks either something electrical or some sensor messed up.He took apart look at electric ribbon nothing looked over puts back together..turns on and it goes completely blank again..no error codes..any suggestions
Feb 22, 2008 | Cooktops
Cooktops Logo
787 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
