Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
CAN'T RECEIVE INCOMING CALLS
THE PHONE WILL DIAL OUT & HAS A RINGTONEBUT WILL NOT RING FOR INCOMING CALLS, BUT THE PHONE HAS A DIAL TONE
shaggyrat
  • 1224 Answers
SOURCE: Uniden Phone
goto the name and hit store it will restore the name and when going threw the store process it should show you old parameters
or goto phonebook find name and edit its preferences for that name phone ringers are set ringers so when you pick one for gereral use thats going to be the general use ringer but special ringers is what i descriped in first part
menu handset setup then ringers for a general ringer you can change to a more pleasing ringer but over all cant turn off
Posted on May 10, 2008
SOURCE: Phone problems
I'm unable to get a connection on my phone when i press the talk button is says connecting and then it states unavailable.
Posted on Sep 29, 2008
SOURCE: Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Posted on Jan 08, 2009
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
youngjuls
  • 3 Answers
SOURCE: No dial tone and no ring on Uniden 5.8 GHz
I have the same handset and the 2nd one seemed to stop working after working great for 2 yrs. I placed both sets together and hit the PAGE button on the main handsets cradle. Both phone's were paged and, for some reason, the 2nd handset reset. It worked for me...or at least, something in what I did worked. BTW, H1 and H2 shows in upper right side (or at least it did after I paged)...and I made sure to put the phones in the correct cradle (H1 is the main handset). I just did this so hoping it continues to work!
Posted on Oct 23, 2009
There's no dial tone -- what do I do to fix this?
It's possible the "tip" and "ring" are reversed, sometimes that'll block dial-tone. Try another jumper between your wall jack and the phone. You should also try a different phone plugged into that jack to make sure it's ok.
Nov 14, 2014 | Lands Phones
GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
May 21, 2008 | Uniden Cordless Phone
I have a GE Cordless 5.8 gigahertz handset and digital answerer. I can see the red light flashing during an incoming call, but hear no dial tone and no ringing. I just replaced the battery. The handset...
Did you pay the Bill ?
this seems as if it,s incoming calls only. Check the line with an alternative Phone. This will verify the lines good. And eliminate that One.
Also check if theres A Tone/Pulse setting.
This can also have adverse effects.
If this is on an adaptor fitting with internet access, try removing the adaptor, and plugging the phone direct into the Socket.
Or try the phone on a seperate or diferent Socket.
Hope This helps.
Mike @ compurepair.
Mar 05, 2008 | Lands Phones
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
HP laserjet 3055 Have dial tone. With phone can call out and receive calls. When sending fax keep getting Result: No answer
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 13, 2010 | HP LaserJet 3055 All-In-One Printer
BlackBerry Pearl 8130 - no ring tone on incoming calls, can only receive text and voice mail
In your BlackBerry Pearl 8130 handheld go to Profile and then select Advanced, Highlight any one the profile then click on menu key and then select Edit and then select Phone, Then select Out of holster, Press menu key select the tone. You will be able to hear the tone for incoming call.
Oct 18, 2009 | RIM BlackBerry 8700c Cellular Phone
Cannot get dial tone
try to make an incoming call to the phone in question by dialling the phone number from a mobile or whatever.if the phone does not ring then the line itself is not connected or has a wiring problem.
so if no dial tone and no incoming calls then check the line itself
Dec 20, 2008 | Lands Phones
Trouble with the fax function
There is no setting to make this work, sorry.
This is just the nature of digital phone service. Some fax machines will work, and some won't, but generally the extremely high priced units are the one that will work (of course, right?)
It all has to do with the way the fax machine "hears" the ring, or detects the dial tone.
The only other option is to use the HP as a scanner, and send the faxes through the internet using a 3rd party fax program.
I know this is a pain, but unless you want to shell out big bucks for a new fax machine, it may be the only answer.
Apr 07, 2008 | HP OfficeJet k60xi InkJet Printer
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
822 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
