Question about Delta Luv Delta - Baby Products 5-in-1 Crib
Bathtub spout broke off and the pvc pipe came with it .
I can see the pipe and was trying to repair it but found a cupling on the pipe behind the tub wall and cant git to it to cut and repair it do i half to pull the shower ub out to repair
  • 68 Answers
in shop visit weeklyvisiters.blogspot.com
Posted on Sep 10, 2009
My husband in stalled in shower vavle body. When bathtub is filling, water comes out shower head any ideas.
It's possible you installed the valve upside down, all values should be labeled in some way marking either hot and cold or it will say the word up where the riser tube port for the shower head is. If that's not the case remove the tub spout and check for any obstruction sometimes during tile or constructing debris can get into the pipe for your tub spout. Lastly the diverter on the tub spout could be bad. Try a new tub spout
Mar 05, 2016 | American Standard Home
Can you fix a broken pvc pipe
more specific please. so your saying that the actual faucet sticking outta the wall is PVC and not a Brass for plated brass pipe? Also what type of valve do you have. Is it a single knob valve that you rotate to turn on as well as adjust your water temperature, or is there 2 knobs one for hot and one for cold?
A picture would help me answer your question a lot easier
Jul 01, 2014 | Delta Faucet Delta RP17453 Pull-Down...
Water is squirting out of pvc pipe under the tub. pvc pipe has some sort of "breather"
This is the safety check valve. If water is coming out of it then either the water is too high in the tub when it is being used or there is a blockage somewhere in the system making the water go to that valve.
US Parts Center
Feb 08, 2014 | Home
I am trying to replace an old delta monitor 1300 diverter spout. It seems when I take off the spout it has a threaded part in the middle of copper pipe . The spout itself has a plasticinsert with threads....
Tub spouts are pretty much interchangeable although you may find the replacement spout cannot be installed easily because the threaded copper stub does not extend far enough to engage the threads inside the spout.
Nov 28, 2013 | Delta Faucet Delta T13422 13 Series...
I broke the pvc pipes that transport the water to the jets. I need replacement pipes. Where do I get those?
the PVC pipes used to plumb bathtubs can be either rigid PVC pipe or flex PVC pipe. You may use either kind and is usually available at your local Home Center.
Jan 10, 2011 | American Standard Colony Hydro Massage...
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
Leaking pipe in a jacuzzi hot tub
The only product I know of which will do what you ask is an item called Plast-Aid Acrylic and PVC repair kit. Google it and you will find the website. It is about $20. and it works like a charm. good luck
Jan 10, 2009 | Home
Tub spout. Moen
Hi handie Man,
I'm Harvey the Master Plumber.
Your problem is: Just bought a new tube spout to repalce my old one. The new spout same as the old, very common spout.. the inside of the spout has a (white) PVC threaded pipe in it with a smaller tube inside that as a O-ring in it.. You tried to unscrew annoying pipe but it wont budge.. and you dont want to ruin it incase you end up returning it. You think its just a reciver for a 1/2 inch copper pipe (which will fit).
That is exactly what it is. You've purchased a universal spout which requires a 1/2" copper pipe coming out of the wall. If you're not up to changing to that, take the old one to a plumbing supply. If you're lucky they might have a direct replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 15, 2008 | Home
Delta Luv Delta - Baby Products 5-in-1 Crib Logo
148 people viewed this question
Top Delta Luv Baby Gear Experts
Dan
Level 1 Expert
Oloyede Monsuru
Are you a Delta Luv Baby Gear Expert? Answer questions, earn points and help others
