Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
LCD Monitor Repair
HP Pavilion f1504 LCD monitor died without notice. Any clue as what went wrong?
  • Anonymous Mar 06, 2008
    same
  • 40 Answers
With the computer on and the monitor connected, shine a flashlight at a slight angle on the screen and see if you can make out a picture. If you can, then it is most likely the ccfl inverter, if not possibly the power supply of the monitor.
srich
Posted on May 27, 2008
My HP L1730 Model PE1238 17 inch lcd monitor wont switch on. it makes a sound every couple seconds. it sounds like it does when its coming on but its cut short fix please ?
How to repair HP Pavilion f1703 lcd monitor - YouTube
? 5:48
https://www.youtube.com/watch?v=rFXyIMAq64o
Jul 11, 2010 - Uploaded by z28r2fast4u
How to repair HP Pavilion f1703 lcd monitor. ... 17:38. HP L1750LCD monitor repair - Also applies to ...
HP W2207h LCD MONITOR-HOW TO TURN OFF OSD ...
h30434.www3.hp.com > ... > Video/Touch
Solved: MY EXTERNAL, HP W2207h LCD FLAT SCREEN MONITOR OPERATES FINE WITH ... HP ENVY 17t Touch,i7-5500u,16GB, 256 GB SSD (on loan)Missing: l1730 ‎pe1238
Using and Adjusting Your Monitor - HP Customer Support
Dec 25, 2015 | HP Computers & Internet
My HP monitor was working fine then randomly one day it went dead, I turned it back on and I could see the screen and what it displayed for about 2 seconds, then the screen dies again. The power button is...
Sounds like your monitor is going dead. If its under warranty that would be the best way to go. Specifically it sounds like the power inverter is dead or there is a busted capacitor.
Mar 12, 2011 | HP Pavilion F1703 17" LCD Monitor
My monitor is flashing different colors... it wont start up
chanel_luv_u, Could be possible internal SMPS/CCFL inverter power supply problem. If the PC is ok with different "known-good" monitor connected to PC, then vs17 monitor will need some work done on it. Do some reading here first for some clues!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flatpanel-disolay-blackout-solution/ The first place I would look at on ANY ccfl back-lit lcd monitor that starts doing "very strange things" would be the units "switch-mode-power-supply/CCFL inverter circuit". Try YOUTUBE for video clips of DIY lcd monitor repair to see if unit can be fixed for less than $6 in parts. Keep this in mind though, Your vs17 isn't any different than any other ccfl back-lit lcd monitor in it's basic design and operation. Do some reading of fixya LCD monitor technicians profiles for more info. Let us know what plans you have after you do your research. Bye for now. 12fixlouie
Jun 09, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Hp pavilion f1703 lcd monitor
problem with your ccfl lamps or inverter, consult your nearest LCD repair center..
May 09, 2010 | HP Pavilion F1703 17" LCD Monitor
My hp pavilion f70 flat panel lcd monitor comes on and works fine with a beautiful picture...for about 1/3 of a second. then it goes blank. any ideas how i can fix this or what might be wrong?
Hi:
The symptoms you describe, pretty much diagnose a failed High Voltage power supply board problem in the monitor. This is usually cost prohibitive to repair, as LCD monitor prices have dropped a bit, so your monitor is beyond economical repair.
Nov 30, 2009 | HP Pavilion F70 17" Flat Panel LCD Monitor
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion dv9500t Vertical Line Issue
try connecting an external monitor to the unit. if you get the same or similar issues on the external monitor then you have a GPU issue on the motherboard. It will need to be REFLOWED or replaced. If you do not get the same issue on your external monitor, then you need to replace your LCD. Our shop replaces these LCDs for 140-180 so i imagine you should be able to find something similar in your area!
Good Luck!
Ruben
Dec 18, 2008 | HP Pavilion DV9500T Notebook
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
87 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
