Question about Turboair TAS-24H Split System Air Conditioner
Keeps turning off both inside and outside units
  • 68 Answers
in shop visit weeklyvisiters.blogspot.com
Posted on Sep 10, 2009
My akira split unit, indoor & outdoor light keep flashing, when it is turn on but outdoor unit does not running. please don't tell me to seek the spcecialise.
The relay for the outside unit is not working. The thermostat activates bot inside and outside relays, so the outside relay is bad.
Apr 26, 2016 | Heating & Cooling
My a/c turns on for few minutes and condensor off but inside fan keeps running
does the outside unit have a hum from contactor being pulled in by the thermostat be the first place i would check, i find a capacitor and replace it on the outside unit if u want no repair man to find the problem and go from there
Aug 17, 2014 | Heating & Cooling
My breaker trips when the outside unit tries to turn on. The inside furnace runs. I cut the inside unit off and the breaker doesn't trip. I manually turn on the outside unit by depressing the cont
Hello, there is a short to ground somewhere, check all the wiring from the inside un it to the outside unit and make sure nothing is touching metal.
Jun 10, 2012 | Goodman Heating & Cooling
Cooling doesn't stay on
The outside and inside coils may need cleaning. Clogged coils cause excess pressures and heat of the freon that can cause safety switches to shut er down. Eveen a faulty power relay in the outside unit.Otherwise you may need a serviceman to locate the cause.
Jan 21, 2012 | LG LS-L1210CL Mini Split Air Conditioner
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
I have a Rheem Heat Pump unit. This winter, the outside unit fan at times trips off, but the inside unit keeps running continuously. I woke up one morning & it was 62 in the house. The inside unit ran...
Dear Friend!
Due to very low ambient temp, the fan will not run. Once the pressure build up, it's automatically run for some time and again cut off. But if you keep Heat mode and still tem not raised in your room means the reversable valve not working and hence the compressor and out side fan also will not work. Keep "Heat" mode and temp setting +29 to get better heat. Hope is it helpful?
Dec 10, 2010 | Heating & Cooling
My air stops running inside before it get to the temp. Its set for but the outside unit keeps running and after a minute or two the air will start blowing inside again but the outside unit never turns off...
you have a possible thermal overload problem in your furnace blower motor dirt will cause this problem when it doesnt allow air across the windings of the blower motor if not dirt the motors going bad and getting hot use a shop vac and eliminate dirt keep your filter changed and your evaperator a coil may also need checked for cleanliness this will require cutting into plenum my advice someone qualified and remember dirt kills
Jun 18, 2010 | Goodman CKL36AR36 Air Conditioner
Can i run the fan on my inside unit if the outside unit is not working
You should be able to run the fan on the inside unit if the outside one isn't working. If you're worried, turn off the circuit breaker for the outside unit. If you don't know why the outside unit isn't working, check the circuit breaker at the breaker panel, check the breaker inside the box that electrically connects to the outside unit, and check the outside unit for a reset button.
Oct 15, 2009 | Heating & Cooling
Outside unit will not start...while inside unit blows warm air
probably a.c. was left with out a gas,and compressor will not start and there is no cooling.
Jul 04, 2009 | Heating & Cooling
My outside air conditioning unit keeps starting for a few seconds, then stops, then starts again and then turns on. The house is cool but it keeps doing this all of the time.
Constant starting is going to run up your electric bill a lot. Have the unit checked out by a professional repairman. It could be as simple as a weak relay, or your outside coils could need cleaning. Definately check the inside coils, there are coil cleaning sprays that will clean them good.
May 08, 2009 | Heating & Cooling
Turboair TAS-24H Split System Air Conditioner Logo
101 people viewed this question
Top Turboair Heating & Cooling Experts
Steve F
Thomas Woodburn
Thomas Woodburn
Andy
Are you a Turboair Heating and Cooling Expert? Answer questions, earn points and help others
