Question about Refrigerators
My refrigeration stopped getting cold. I did some troubleshooting on the unit and found the the start ralay on the compressor clicking and the compressor hot. I installed a new ralay and I hear it clicking with the compressor running about 10 seconds then it clicks off.
  • 10,515 Answers
Read the below explanation and you would find out the fix :-
The components on the side of the compressor are called your relay, starter and capacitor. There are a few different styles but they pretty much do the same thing. They allow the electrical current to enter the compressor.F the compressor is going bad, say shorted windings in the motor, this will cause the compressor to draw to many amps of electricity. When the compressor draws too much current, the overload will overheat and "CLICK". When you hear that click, that is the sound of, your refrigerator isn't going to get cold anymore and you better fix quick noise. That's why you're here.
The clicking noise is very distinct and it will sound like it's coming from under the refrigerator or from the back. You may also hear buzzing. The overload will click when it cools down and lets current through the circuit again. So, click off, click on. But if the component parts are bad or the compressor is bad this cycle will happen again, and again, again, and so on and so forth. Usually about the rate of every minute or so.
Now, there are a few other things that will cause this to overheat and shut off. One is if your condenser coils are covered in pet hair and haven't been cleaned in some time. Lint, dust, hair, who knows what else can be there but you get the point. If those coils are not kept clean, the compressor will run hot. That will cause the overload on the side of the compressor to overheat and "click"-no cool. Unplug the fridge and clean the coils. This may fix the problem if the overload or compressor weren't damaged. You will know right away. If the fridge runs fine after cleaning the coils then you are okay. You will know usually within a few minutes if the something has been damaged. It will still click.
Another thing that can cause the click is an adaptive defrost control board. It contains a relay that sends power to the parts on the side of the compressor. When the defrost board doesn't send full power to the compressor, this causes an increased amp draw to make up for the voltage drop. Increased amp draw equals "CLICK"
One more thing that may cause this clicking sound is the condenser fan not working. The condenser fan is the fan that is next to the compressor. It has a couple jobs. Evaporate the defrost water and keeping the heat off the condenser coils and compressor. If the fan isn't running when the compressor is running, guess what will happen. "CLICK" I think you know why by now, but just in case, the compressor overheats and the overload on the side of the compressor, protects it by shutting off the power. Hopefully if your fan motor was bad, the overload did its job and saved your compressor. You can place a separate fan on the floor blowing on the compressor and coils to temporarily get you by until your new parts arrive.
Okay, you cleaned the coils, got a fan if you needed one and it still clicks, now what? The first thing to do is replace the components on the side of the compressor. Hopefully the compressor starts up and the new components don't click like the old ones. If they don't click you are good to go. Good job, you just saved a bunch of money on appliance repairs.
But what if it still clicks? Well, to put it nicely, your refrigerator may need to find a new home(scrapyard). That means your compressor has internal damage or you have some sort of freon restriction. If your refrigerator is less than five years old it may be covered by the manufacture's limited warranty. That means this repair will not cost you. But, if it's older than that or you don't have some sort of extended warranty plan, this repair will cost you at least $300. And if you are really unlucky it could cost around $600. The difference in price being whether you only need freon work, or you need the compressor replaced.
I think I've covered the basics. You now know what the annoying clicking sound is when your refrigerator gives up and stops getting cold. The clicking is capable of happening periodically. Make sure the refrigerator isn't running in temperatures above 85 degrees. Don't let the refrigerator be exposed to direct sunlight. Keep the coils clean. Don't leave the doors hanging open for long periods of time. If you are having a defrost issue this sound could be heard. That is because with a defrost issue, the compressor runs constantly and that will cause it to overheat.
Any further help, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 09, 2009
Stopped getting cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Maytag Refrigerators
The frig and freezer just stopped working. Stop getting cold. Cleaned everything out and it started working then stopped again.
heatman101
Aug 11, 2011 | Frigidaire Refrigerators
Fridge freezer stopped being cold turned it off for 4 days but still not getting cold
heatman101
Jul 19, 2011 | Refrigerators
My refer and freezer just stopped getting cold. fan is running ,relay on compressor clicks on and off every few minutes
heatman101
May 06, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My samsung side by side stopped cooling and freezing. Found a stick liquid on the floor.
heatman101
Mar 28, 2011 | Samsung Refrigerators
My fridge has just stopped getting cold.
heatman101
Mar 21, 2011 | Fisher and Paykel Refrigerators
Amana model# sxd25aw, was working great then freezer just stopped getting cold, freezer is about same temperature as refrigerator now, even refrigerator seems not as cold as normal. can hear compressor...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Jan 18, 2011 | Amana Refrigerators
Fredgerator and freezer just stopped getting cold nver night.
Refrigerator
heatman101
Dec 15, 2010 | Whirlpool Refrigerators
My refrigerator has stop getting cold along with freezer, this has happen before .. Does this unit have a reset button ? If so where? the refrigerator is functional the units light is on the inside.
heatman101
Nov 18, 2010 | Kenmore 64802 Top Freezer Refrigerator
What would stop your refrigerator from getting cold
heatman101
m,..
Oct 14, 2010 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
