How do I remove the mainboard battery on a Toshiba NB200 netbook, in order to reset the BIOS / CMOS passwords?
    President:
  • 2,600 Answers
I know this not exactly what you are looking for but its all Ive found so far....it is a tear down guide for the NB but it is in Italian...lol It has good pictures as a guide though. I'll keep looking.
http://netbookitalia.it/toshiba-nb100-guida-al-disassemblaggio.html
Posted on Sep 10, 2009
Locked out of my samsung n 130 netbook. how domi reset
Often if you remove the BIOS battery for a period this will clear the BIOS password. Sometimes there will also be jumpers on the mainboard to do this job.
Mar 21, 2014 | Computers & Internet
Toshiba satelite bios password recovery
On laptops there isn't an easy way to recover passwords in the BIOS. Sometimes you can reset the password. Other times, you'll have to contact the manufacturer to get it reset.
Some laptops will allow you to reset the BIOS password by pulling the CMOS battery. The CMOS battery is typically located under one of the bottom panels for access to the memory or wireless cards. Some models have the CMOS battery connected by a small wire with a clip connector, others have the CMOS battery placed directly on the motherboard with a metal retainer clip.
Here is a link to a removable CMOS battery with wires: http://www.laptopparts101.com/wp-content/uploads/2008/12/removable-cmos-battery-560x420.jpg
Here is a link to a CMOS battery that is directly on the motherboard: http://www.laptopparts101.com/wp-content/uploads/2008/12/coin-cmos-battery-560x420.jpg
On a laptop, if you unplug the power cord, remove the laptop main battery and then remove the CMOS battery - and then wait at least 5 minutes, some models will blank out the BIOS password. Not every BIOS password can be erased by removing the CMOS battery - but if you are comfortable working on the laptop parts it is worth a try.
If removing the CMOS battery doesn't fix the BIOS password, the only option left is to contact the manufacturer for a reset. (If you took your laptop to a certified technician - they would just contact the manufacturer for the reset, and then bill the time to you!)
The number to contact Toshiba is 1-800-457-7777.
Nov 19, 2011 | Toshiba Computers & Internet
Need bios jumper location to reset bios password
The easiest way to reset bios password is to turn off the laptop completely and unplug it from the power outlet, open the bottom panel of your laptop, locate the CMOS battery and remove it for a minute and put it back in.
Nov 11, 2011 | Toshiba NB205-N210 Netbook
NB205 has HDD password. How can i remove it?
- Seems like a BIOS password issue. You need to reset the BIOS and in order to do that you need to take out the CMOS/Lithium battery out for about 5 seconds and put it back in.
- Make sure you are static free and the laptop should be turned off completely, battery and power cord unplugged before opening the bottom panel.
- Locate the CMOS battery. Most of the time it is located under the memory modules or hard drive depending on the brand and model of the laptop.
- If the CMOS battery is soldered to the motherboard and you don't have experience with soldering, i suggest you bring the laptop to someone who knows how to.
- If you do not want to remove the CMOS battery, what you can try is short circuit the jumper settings. Click here for tips on how to locate jumper settings.
Hope this helps.
Sep 10, 2011 | Toshiba NB205-N210 Netbook
Hello, My name is Vahe and I have got the following problem, I have forgot my BIOS password and I can't to turn on. Laptop model Toshiba satellite A200-13M. So I have got some solution to delete...
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Toshiba (K000002020) Motherboard
Toshiba nb200 bios password
To reset the BIOS read the information from this link: http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
In case of your laptop the easiest method would be using Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery especially with Toshiba laptops as they have the battery soldered to the motherboard.
Feb 11, 2011 | SGP Toshiba NB200 Laptop Cover Skin [Cube]...
Hi i am an indian.sir my laptop toshiba model:satellite A130/A135 Series is asking for bios password.ples help me.
Hi.
If you dont remember the BIOS password, you may remove it by resetting the BIOS password.
Please follow the below steps to reset the BIOS password:
1) Please remove the bottom casing of the Notebook.
2) Once you have removed the below casing, you should be able to see a CMOS Battery.
3) The CMOS Battery will be of a size of a coin.
4) Once you have found the CMOS Battery, please remove and re-insert it again.
5) The CMOS Battery will have the information about the Computer Date, time, BIOS Password etc.,
6) Removing and re-inserting the CMOS Battery will reset these settings, which will also remove the BIOS password.
Please perform the above steps and let me know the results.
Hope this helps.
Please feel free to contact for further information and assistance.
Oct 02, 2010 | Toshiba Computers & Internet
Blank screen asking for password
I presume this is the CMOS or BIOS password.
Turn the unit over and find the ram cover, remove the ram locate the two brass bars near where the ram was. Take a paper clip and bridge them to short out and reset bios password.
replace ram and turn on
please rate our help to keep the FREE service online
Aug 27, 2009 | Toshiba Satellite A135-S2386 Notebook...
Computers & Internet Logo
699 people viewed this question
David Payne
David Payne
