Question about Toshiba Satellite A105 Notebook
It powers up and thenshuts itself down over and over when screen comes up after sevral attempts nothing works
  • 776 Answers
Please have the operating system checked and possibly re-loaded.
Some of the files/drivers have gone bad which has resulted in to the OS going bad on the laptop.
Posted on Sep 09, 2009
My galaxy tablet will not turn on and or charge
hold the power button down for 10-15 seconds to force a power off. When turning back on, hold the power button down until you either feel it vibrate or something comes up on the screen.
Jan 13, 2014 | Samsung 7 in. Galaxy Tab 3, 8GB...
Ne demare pas quand il fais froid
check glow plug system light in dash will go on even with a bad relay
check at the glow plug itself also check the glow plug itself
check your block heater if this check out ok try warming up the ficm
the one mounted on the valve cover left side with a air blower for
sevral minutes (10 min ) on hi and if unit stars you need new ficm
work for me on sevral unit so far good luck
Jan 17, 2011 | 2004 Ford F350
Laptop will not power on. When laptop lid was
System board has failed you will have to replace it.
Feb 23, 2010 | Compaq Presario 700 470024-192 Notebook
The ice maker works perfectly in my Sears Kenmore Elite Refrigerator, but the ice crusher doe snot work. When i put the glass under or I push the lever, no ice comes out. I have removed all the ice sevral...
Push the lever to dispense ice and listen for a small click sound,(the micro switch). If you hear a click you will have to determine if there is a broken wire to the dispenser motor or if the motor itself is defective, This will not be a visual diagnosis unless you fine a broken wire in the hinge area.
Eric
Nov 19, 2009 | Frigidaire FRS-26DR7D Side by Side...
The tv keeps trying to come on with the beeping like a bird then
Most failures with these LCDs are due to a defective power supply. The repair itself might be a DIY with basic hand soldering skills and possibly know how to use a multimeter (optional).
The defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
*When power button is pressed, the LCD will attempt to turn ON but it turn OFF again.
Turns OFF by itself.
Needs to be unplug to make it work.
Works for a few minutes then turns OFF.
If you need further assistance, write to jah2mil@hotmail.com
Aug 18, 2009 | Samsung LN-S4051D 40 in. LCD Television
Comp. powers on, shuts down three times then goes into powersave
You may want to check the power supply fan whether it works properly or not. Also, you may need to check your BIOS setup if you had done anything with it.
Jun 23, 2009 | Dell Inspiron 530 Desktop Computer
My 2005 Silverado 2500HD has a secondary latch that's preventing me from lowering the spare. How do I remove this thing and lower the spare?
you may get lucky if you yank the plastic sleeve back and forth that rod goes into to crank down until it comes off spray some PBblaster or wd40 sevral times up into that area and if possible above the foot that is holding tire.Wait about half hour attempt to crank up first and then downward.
Jun 19, 2009 | 2007 Chevrolet Silverado 2500HD
No power-up
See if this helps-
Unplug the power adapter. Remove the battery. Plug in the power adapter. Attempt to power up.
If that doesn't work-
Power down. Remove the hard drive and CD drive, also floppy drive if you have one. Disconnect the cables to any external devices that you might have attached. Remove all of the memory cards. Replace 1 memory card in the main slot,only. This will reseat the memory card. Power back up and see if the system comes up to a BIOS screen. If not, and you have more than 1 memory card, try swapping to the other memory card. If BIOS comes up, start reinstalling each item (Hard drive first) one at a time, attempting to bring the system up after each item is installed. If the BIOS screen doesn't come up with everything disconnected, you'll need to disconnect the LCD screen (internally) and hook up an external screen. If BIOS shows up on the external monitor at this time, you have a bad LCD screen.
If nothing in this process seems to work, you probably have a bad mother board.
If you have any questions, please ask.
Thanks!
Ron-
Nov 09, 2007 | Toshiba Satellite M105-S3004 Notebook
Toshiba Satellite A105 Notebook Logo
14 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
