Question about Dryers
Stackable Kenmore shows PF and chugs once then dies. I reset breaker although not tripped?
  • Dryers Master
  • 8,220 Answers
PUMP Failure. Clear the garbage from the pump and retry. MANUAL
Posted on Sep 09, 2009
I have Kenmore elite oasis electric dryer when you push start button it goes to pf code ive tryed holding down start button & it just flashes & is back to pf code how do I reset it ?
try unplugging it from power or tripping the circuit breaker(which might be easier). then re energize it and see if it resets. good luck.
Jul 29, 2016 | Kenmore Dryers
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Have kenmore 61951 dryer PF comes on go thru the steps it turns on and then shuts off what could be the problem
PF is a power failure error meaning electricity has been interrupted to the machine. Any electrical interruption to the machine such as a circuit breaker being reset or weather related power outage can cause a PF error code. Try resetting the appliance by disconnecting it from the outlet or switching off the circuit breaker for 20-30 minutes, then restore the power. If the reset doesn't work I suspect the control board has failed.
Jan 12, 2011 | Kenmore Dryers
Circuit breaker tripped, i reset it and the dryer read PF, cleared that...but now the dryer just beeps when youy hit any button like start. The dryer is a kenmore h3 gas dryer
try resetting the breakers again as they may have tripped again as sometimes they only move a bit and they look like they are ok but they are not.I would also unplug the dryer for thirty seconds to reset it and start again.
Oct 06, 2010 | Kenmore 82822 Electric Dryer
My Frigidaire dryer will not start. It shows a PF trouble code. What does this mean?
PF is showing you that there is a power problem. Check your dryer circuit breaker at the power panel. This can be a sing that one of the 2 breakers has tripped. Push the CB hard to OFF and then back to ON. Then try and start your dryer. If that does not work just respond here and I will help you.
Try selecting "No Heat" after resetting the CB and see if the dryer starts. If it does you could have a bad heating element that caused the breaker to trip to begin with. Sometimes when the heating element fails the broken link will contact the chassis and cause the CB to trip. Heating element failures are usually caused by poor airflow. You may want to look for any signs of lint in your dryer to include the lint filter area and all the way to the outside wall exhaust point.
Kelly
Oct 01, 2010 | Frigidaire Electric Dryer
Power Failure without tripping breaker
Sounds like an overheat code tripped due to obstruction in the exhaust. There is also a vent tube on the bottom of the dryer that could be loose.
Jul 27, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Kenmore double oven - model# 7947773403 - code PF is on and oven won't turn on
Pf is 'power failure'. Have you checked breaker? Turn breaker off and back on to reset.
Sep 26, 2009 | Kenmore Ovens
Kenmore Elite HE3 Dryer PF on control panel,
HI, there may have been a slight power failure within the home breaker unit or the dryer may have lost power to the control for some sort of reason.
I recommend a thorough inspection of the terminal block on the back side of this unit. make sure the power cord is attached tightly and the wall outlet is secure and holding the power cord correctly. if everything looks great with the terminal block and the power cord is plugged in the outlet correctly, simply unplug this unit for 5 minutes to reset the control. after the 5 minutes are up, plug the unit in once more and the PF alert should reset.
Make sure the breaker box in your home is working properly. (the actual breaker switch for the dryer must be in the on position)
Apr 26, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
