Question about Dishwashers
Kenmoore Dishwasher Problem
My 13 year old dishwasher is not getting water to it. Runs through the cycle, dispenses soap and goes through the heat cycle but no water is getting to the washer. It worked fine a couple days ago. I think it's a solenoid?? No kinks in the water line can be seen.
  • Anonymous May 06, 2008
    i put on a new inlet valve. still don,t let any water in..
    Problem Solver:
  • 14 Answers
Try the float inside the dishwasher to see if it moves up and down freely .its usually about 3x3 round and resides near the heating coil this has a switch under it that controls the solenoid valve
Posted on Dec 10, 2007
Soap door opens during cycle, but soap does not dispense??
Hello Eric, thank you for your post!
I understand that the dispenser on your Frigidaire dishwasher opens but the soap is not dispensing into your dishwasher. How old is your dishwasher soap? If it is around a year old you may need to discard it and use a new soap. Also check to make sure when you stack dishes that they are not obstructing the arms from reaching the dispenser. Make sure your spray arms are clear of any debris that could block the distribution of water inside of your dishwasher. You may need to connect with a professional technician for proper repairs if these steps do not correct your issues. I hope this information is helpful to you. -Matt
Aug 02, 2015 | Frigidaire Dishwashers
Our dishwasher is not dispensing the soap. I have tried using the cubes (stays in wells), tried powder (it turns to a cake of soap) and I have tried liquid but you could see it ran down the door. Some...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Dishes are not clean if water is hard or when more detergent is used than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results. You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine. Hope this helps...
Please post back if more information is required.
Daniel
Jan 10, 2011 | Maytag Dishwashers
13 year old daughter put liquid dishwashing soap in the rinse dispenser. Now all dishes come out covered in soap scum. How do I get liquid dishwashing soap out of the rinse dispenser?
Sorry but thats funny!!lol About the easiest way I know to tell you is take a turkey baster or marinade injector & draw as much as you can out of the reservoir,fill it with water & repeat until you get very little foam when putting water in it.Fill with rinse aid & the rest will just have to work its way through.Should be fine after a few wash cycles.
Jan 07, 2010 | Admiral 24 in. DWUA601 Built-in Dishwasher
Dishwasher is leaving soap in dispenser and dishes aren't clean
Look for debris in the holes of the wash arms. Is the soap dispenser opening? If so you probably have either no water in the machine or no ciculation. Also be aware sometimes a fill valve will work for the first few fills and then not work once it is heated up a little. And the valve could be clogged causeing low or no water to enter the machine.
Aug 06, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dishwasher - Soap Stuck in Cup If you have dishwasher detergent stuck in the soap cup after a full cycle, please check for the following conditions:
  • The water temperature should be at 120 degrees (140 degrees if your dishwasher has water heating capability). Check your water temperature Check your water temperature.
  • Make sure the soap cup is not blocked by anything.
  • Allow the dishwasher to fill and make sure it is getting a proper amount of water. The dishwasher should fill for about 90 seconds. On permatuf models, the water should measure 3/8" above the island near the center of the tub. On all other models, the water should measure about 1/2" below the heating element.
  • Check the lower spray arm for any blockage in spray holes or items that would restrict its turning.
  • Make sure the soap cup has opened at the end of the cycle.
  • Check the sump area inside the dishwasher for any restrictions.
Apr 09, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher
I have a kenmore dishwasher (about 10 year old) it won't turn on. It just buzzed when set to wash. What can I do?
May 15, 2008 | Dishwashers
"Sensing" Light
There is a relay on the soap dispenser, if it is a Kenmore quietguard 4, I had the same type of noise, the repairman replaced the dispenser, which to me made no sense, because the relay is activated from the control board. After the $130. for the soap dispenser, he ended up replacing the control board for another $160. Now the dishwasher only goes up to the dry cycle and stops. If you press the heated dry button and then the heated wash button 5 times each, the entire control face will light up and it will do some kind of reset and try a new cycle. I have tried the button pushing and it worked great till it got to the dry cycle, so I am looking for another solution without involving Sears. Good Luck!
Jan 17, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
1h (?) signal, and soap dispenser doesn't open
The part called a Wax Motor (about 2 inches) inside the door is responsible for opening your dispenser.Check it / replace it.
Oct 09, 2007 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
115 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
