Question about Maytag SAV4655A Top Load Washer
We have a Maytag toploading washer (SAV4655AWW). The stem holding the knob for the water level broke off. I think I need to replace the entire switch. Is this something I can do myself?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Yes you can do it.
For now just turn it with a plier until you buy a new knob or get one from another washer machine go to the lockal repair shoppe or the salvage place to get a replacement.
Vitally
Posted on Sep 09, 2009
Testimonial: "Thanks! I opened up the back last night and it looks like it'll be an easy fix."
The part that controls the water level is broke
You didnt give a model number, but I will assume it is a top loader with a level selector knob. Is the stem still visible, or did everything break off? You can remove the facia panel with the phillips head screws on each end, and by removing the program selector knobs by pulling straight out. The level selector is fairly simple to replace. there should be two wires and a clear rubber tube. get your new part from an appliance part store ( less than 30 dollars). unplug the machine, and transfer the wires to the new part one at a time keeping them in exactly the same place. undo the hose clamp ( if present, sometimes just held on by pressure fit) and connect the pressure tube to the new level switch. re assemble the facia panel, plug the machine back in, and give it a test.
Nov 20, 2010 | Maytag Washing Machines
Leaking water
When your Maytag top load washing machine leaks water, you will need to check the following parts until you find where the leak is coming from.
The water valve: The first place you need to check is behind the washer. Check the two fill hoses and the water mixing valve.
Check for pinholes or cracks on the plastic body of water mixing valve.
Remove the front panel : The next thing you need to do, is to remove the front panel so you could see the tub and the hoses.
Set the washer on the regular cycle and turn it on so it could start filling.
Use a drop light and check all the hoses under the washer as the washer is filling.
Make sure to keep your hands away from any moving parts.
The pump : If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag washing machine to leak water.
The stem & seal : Another place that the washer could leak water from, is the stem & seal on the holding tank.
When washer leaks water from the stem & seal, the water will leak down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110.
Apr 19, 2010 | Maytag PAV2300 Top Load Washer
My maytag topload washer overfilled,
It isn't a sensor problem, it sounds more like your water level tube has pulled loose. This is attached to the outer drum itself. You can see it when you remove your front cover to the right of the outer tub. This tube uses the pressure generated from your tub water level to push air up to your water level selector, which has a rubber membrane that flexes and closes 2 contacts as the water level makes the rubber expand. If that tube is off, the water will just keep running.
Mar 18, 2010 | Maytag MAV3905EWW 13 Cycle Washer
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose first.you can go to an auto parts store and match it up.it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
No screws in the front of my maytag topload washer. do I acess the timer from the rear
Yes you do remove the rear plate by removing the back screws remove the knob off the timer if there is a nut holding it to the frame loosen it but do not remove until you take the back cover off when replacing the timer remove one wire at a time to keep them in order. Please rate if helpful.
Aug 07, 2009 | Maytag Washing Machines
MAYTAG ATLANTIS DRYER TIMER SWITCH
the key is to dismantle the font ofthe knob assy( the small plastic center of knob pulls out) it also acts as a locking ring /clip to hold unto the new timer shaft
Mar 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
No hot water for a Maytag topload washer
Turn the water off and disconnect the hot wat hose from the spigot and the machine. There should be a screen filter in one end. Check to see if the screen is clogged. If it is then replace it. If not then replace the water valve
Jan 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
GE top load Super Capacity 16 cycle washer (one year old)
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing it turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Dec 18, 2007 | GE WBSR3140DW Top Load Washer
Maytag SAV4655A Top Load Washer Logo
220 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
