Question about LG KE600 Cellular Phone
/ffs/main app_layout.r c!1 is missing - LG KE600 Cellular Phone
Impossible to pass candy crush level 2325.the game cheats and blocks
GET A LIFE Ffs. Don't be a useless nerd loser all your life????????????????????????????????????????
Apr 01, 2017 | Facebook Apps
My App Store icon has disappeared from my iPad and my apps do not show up in iTunes. My son can't play Boom Beach without updating it. Please, someone help me put the App Store Icon back on my iPad
If the App Store icon seems to be missing from your Apple iPhone or iPad, give these steps a try to find it.
Fix 1 - Double Check Everywhere
Be sure the icon is not in a folder. Check every Home screen and every folder. Also use search to see if you can find it. From the Home screen, swipe all the way to the left screen, then search for "App Store" to see if it appears.
Fix 2 - Check Restrictions
  1. Open "Settings" from the Home screen.
  2. Tap "General".
  3. Select "Restrictions".
  4. Make sure "App Store" is set to "On" (green).
Fix 3 - Reset Home Screen
It is possible that the icon is on a different home screen or in a folder. Look on other screens and within folders. If you still can't find it, try resetting the home screen by selecting "Settings" > "General "> "Reset" > "Reset Home Screen Layout". This should return your icons to default settings and restore the App Store icon.
Note: If your iPad was provided to you by the organization you work for or a school, it is possible there is software on the device that locks access to the App Store. Ask your IT department for access if you feel this might be the case.
Nov 11, 2016 | Apple iPad Tablets & eReaders
Messages icon missing on iphone 4s
Go to General. Go to Reset. Then go to Reset Home Screen Layout and the app will reappear.
Sep 29, 2013 | Apple iPhone 4S
Apparently there is a problem with Beko refrigeration manufactured between 2000/2006. Please confirm model number in question.
From Beko:-
"The BEKO frost free fridge freezer models affected were manufactured between January 2000 and October 2006. These have a serial number that begins with either 00, 01, 02, 03, 04, 05 or 06. and this information can be found on a label inside the fridge. Beko is making a free of charge modification to all affected models, this modification takes approximately 30mins.
Other Beko branded models and all Beko frost free fridge freezers manufactured after this date are unaffected.
Affected model numbers:
    • CA 5411 FFS/FFW/FFX
    • CA 7014 FFX
    • CA 7015 FFW/FFS/FFX
    • CDA 539 FS/FW/FX
    • CDA 543 FS/FW/FX
    • CDA 645 FW
    • CDA 647 FS/FW
    • CDA 648 FS/FW
    • CDA 653 FS/FW/FX
    • CDA 659 FS
    • CDA 751 FS/FX
    • CDA 752 FS/FW/FX
    • CS 460 FF/FFS/FFW/FFSD
    • CS 461 FFW/FFS
    • CSA 4706 FFX
    • CSB 4606 FFSD/FFS/FFW"
If you find that your model is listed above and is in the correct model year range then you need to click here for further guidance. There is also a freephone number, but it's swamped by callers. Even if you get through you will receive exactly the same advice as you would from the website links.
If you want to know more about what the actual problem is, then click here.
Please take a moment to rate my answer.
Jul 06, 2011 | Washing Machines
What does ffs mean on digital dash in millage an gas?
Hi, FFS means Feedback Fuel System. It is a system by which your engine monitors exhaust gases usually through one or more oxygen sensors to optimize fuel delivery. Usually when an O2 sensor gives an erroneous signal or one that is out of the acceptable range for the comperters preset parameters, it will trigger this fault. In turn, your vehicle will be delivered the incorrect amount of fuel as it runs for optimum performane, economy and emissions. You should be able to obtain a trouble code from the engine's computer to further diagnose which part of the system has faulted.
Please remember to rate this answer! Thanks, Mike
Jun 13, 2011 | 1990 Mercury Cougar
Starter turns over but wont start. We see a flashing FFS on panel
FFS= Feedback Fuel System, Check your ignition module most parts stores can test them once you have it removed, should be located on the side of the distributor.
Mar 24, 2011 | 1990 Mercury Cougar
How do I activate and use the blue key on my HP laptop?
Keep tapping on F10 key while you start the computer to get to BIOS screen and then press F9 and then F10 to exit out of BIOS.
Feb 06, 2010 | HP Pavilion dv6000z Notebook
Keyboard
1. Add a finish keyboard layout (http://www.google.de/search?q=add%20keyboard%20layout) 2. Ask someone to give you either a picture or search for it so that you know which keys are where in the finish layout 3. Start your writing app 4. While the App is active, change the keyboard layout to finish In most XP setups, the Taskbar has a small additional icon where you can switch. (but should also be mentioned in the many pages found by the above search:-)
Oct 20, 2008 | Computers & Internet
LG KE600 Cellular Phone Logo
61 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
