Question about Nikon COOLPIX L10 Digital Camera
I am using the optima sd hc 60 hd 4gb card in a moultrie game cam
And i hook it into my computer and my computer locks up! i just paid good money for a two pack and i cant even use them! why is this??
    Brigadier General:
  • 11,967 Answers
Try using a separate card reader to download your pictures.
Posted on Sep 09, 2009
Moultrie game camera
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 09, 2013 | Cameras
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Every time I put my camera's SD card into my HP Printer C3150, a red exclamation mark light blinks on and off, and the SD card does not appear on "My Computer," so I can't access my pictures....
I am not an expert on such matters. It is possible the printer won't read the SD card because it wasn't formatted before use or was formatted by a computer using 64 bit software instead of 32 bit.
You could try using a card reader and downloading the images to your computer and printing from there.
Aug 11, 2017 | Office Equipment & Supplies
I have put my vacation pictures on a PNY Optima SD HC 60 HD 4GB and now my computer won't read the card. I know the pictures are there because I can see them in my camera. How do I get my laptop to read...
Just a quick thought, have you clicked on the start button and then gone to "my computer"? It will show each drive or memory stick and what it has on it. If it finds it, then drag and drop to a folder.
May 01, 2010 | Dell Computers & Internet
PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
Dec 29, 2009 | PNY 4GB Secure Digital High Capacity...
Moultrie I40 getting error code 480 and wont go into auto mode
ERROR CODE 000480 ?
If this is correct,it relates to: Camera Mod test failed;(4); and under Memory Test, 8= Comms Error.New batteries(good ones) may fix it...
It' not communicating with memory card..ck it's inserted good..press down until it stays down(press again and it will pop up.
Follow instructions on deleting internal memory before installing SDcard.
Also, make sure cam supports kind of card you're using..at 4gb and larger, they become confusing;i.e., 4/8/16mb...older cams won't support some of these. Also there are HC(high capacity); HD(high definition)don't work in these cams..
I posted this for a fix a few days ago, and it turned out to be brand new bad batteries.
Dec 23, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I'm useing the pny optima sd/hc 60 hd 4gb scan disk! it has photos on it useing the camera,nikon coolpixl20. using nikon transfer does not load pictures on computer.
I had same problem. Neither computer nor printer would recognize the SDcard. I took the card to Walgreen's and the card was read just fine. I suspect that we are running XP and do not have the right driver; but I can't seem to find the right driver. Morgen
Dec 07, 2009 | Nikon COOLPIX L10 Digital Camera
Camera won't record on SD card
SD cards have become the industry standard....but beware...there are SD cards NOT backward compatible...i.e.,some cams won't take 2GB or larger; then there is SDHC; SDHC(HD); RUNS FROM 512G thru 32GB HC/HD; ECT...check your cams manual for SD card compatibility.
Apr 27, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Nikon COOLPIX L10 Digital Camera Logo
50 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
