Question about Philips Televison & Video
Dull/cloudy picture - Philips Televison & Video
  • 60 Answers
If the set is 4-5 years old, it probably has dust on the lenses and mirror.
This can cause a murky picture.
If you can remove the front screen assembly, you can gain access to the lenses and mirror. Clean with a dry micro-fiber cloth very gently.
Hope this helps,
Dan
Posted on Sep 10, 2009
Picture cloudy hazy
based on model number it could be cleaning or another issue--with color turned off what color is the screen? On this set with back removed also clean the 3 large lens as if dusty picture will be dull and somewhat dark.
May 03, 2012 | Philips 60PP9202 60" Rear Projection...
How to fix my hitachi 65 tv
If you are saying that the picture is getting darker and you have already tried to adjust the picture through the menu feature on your TV then it is more than likely the cooling fluid around the CRT tubes. Over time the fluid in these tubes gets cloudy and causes your TVs picture to become dull and distorts the color. You can google tv repair kits .com and I believe they will have a kit for your model.
Feb 21, 2012 | Hitachi 57F500 57" Rear Projection...
Lack of cool tones,seems to have pink tint where itshould be white? just got this tv from a friend today,trying to figure out best way to correct picture
Check the CRT fluid in the blue and green CRTs. It should be clear. These sets have problems with the fluid getting cloudy and hence letting less light through. It also gives it a dull picture look. If the fluid is cloudy, you will have to remove the CRT and replace the fluid. Then re-align the CRT via the convergence in the service menu.
Feb 19, 2011 | Philips 50P8341 50" Rear Projection...
I have a PTV916 Model # 60P8341A. I cleaned the lenses and the mirror inside the TV however, I can see alot of dust inside the actual lens. Is it possible to clean the inside of the lenses?
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 13, 2011 | Philips 50P8341 50" Rear Projection...
I have a problem with the color of the pictures that comes out of my canon dslr 400d rebel xti. when i take pictures and compare it with other canon dlsr, my picture looks dull and lifeless. it also the...
hi there,
the common difference between canon and nikon is the color they produce. you can try to change the White Balance setting on your Canon to the suitable mode e.g cloudy, tungsten, daylight, etc.
if you still feel that the picture is dull, don`t be shy to use graphic software such as Adobe Photoshop, Picasa, etc. to enchance the color/brightness/contrast of your picture
hope this will help
Jan 10, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Philips 50p8341 tv has bowed picture in the lower left corner and the top center. I cleaned the projectors because the picture was real cloudy and it looked a lot better, came home from work and discovered...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 19, 2010 | Philips 50P8341 50" Rear Projection...
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
60pp9202 picture very dull not as bright when new
This occurs in projections set because they use ethylene glycol to keep the face of the tube cool. After time it becomes cloudy. A service company can replace it, normally costs around $300.00
May 06, 2009 | Philips 60PP9202 60" Rear Projection...
Couldy image
Your TV most likely has one of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 14, 2009 | Philips 46PP9302 46" Rear Projection...
Need to fix the color and screen
Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
