Question about GE 24 in. GLD4100L Free-Standing Dishwasher
GE dishwasher model #GLD4100L00BB , water not spraying inside.
GE dishwasher model #GLD4100L00BB , Water goes into dishwasher but it is not spraying inside to clean dishes. Soap dispenser opens, but the soap stays on the bottom of dishwasher. Two days ago it made a load crackling sound during the cycle, but the dishes were clean. Second day made the same sound--dishes not clean. Is it the pump?
ngfam1
  • 639 Answers
SOURCE: GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dear friend,
ngfam at you service! happy to assist!
Sprayers or sprayer clogged and or pump weak!
Better call service
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
  • 9 Answers
SOURCE: soap dish does not open during normal cycle on my maytag dishwash
the soap u use may be causing this try cleaning it out real good and use liquid soap
Posted on Apr 20, 2009
  • 2976 Answers
SOURCE: Soap dispenser door not opening up
If the soap door doesn't open all the time, remove the outer door cover and remove any obstructions. There are pieces of styrofoam and cardboard inside the door that come loose from time to time, and prevent the linkage from operating freely. They can be re-glued OR eliminated.
Posted on Oct 18, 2009
heatman101
  • 43501 Answers
SOURCE: soap dispenser not emptying during cycle. Dishes
Checkout this tip that I wrote about that problem...
Dishwasher Repair Problem Detergent Cup does not Open
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Jul 18, 2010
heatman101
  • 43501 Answers
SOURCE: ge pdw7300 leaking water
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
kuyeyu
Posted on Sep 29, 2010
Dishwasher won't drain
Make sure the hose is looped higher than the sink drain before it goes into the Y connection of the drain. This helps the syphon effect and prevents the sink water from draining into the dishwasher.
Feb 14, 2016 | GE Dishwashers
Our GE diswasher is leaving a white film on all the dishes. We are running it on normal wash and heated dry. Can you put vinegar in the dishwasher to clean it out?
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film:
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning your dishwasher unit by using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic. It is the top formula.
Feb 05, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
My dishwasher is not cleaning. It is a GE built in and the serial # is MS721122B, and the model is PDWT400P00BB. It leave a greasy feeling on the dishes and the inside of the dishwasher is dirty and...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
heatman101
sart3
Aug 19, 2010 | GE Nautilus 24" Built-in Dishwasher
No water goes into dishwasher
Check the water inlet solenoid, it may be sticking/stuck Soak in a bit of WD40 or CRC. and, try a bit of percussive maintenance, IE: give it a "bit of a whack"
Feb 09, 2010 | GE Nautilus 24" Built-in Dishwasher
GE nautilus dsihwasher. dishes are not coming clean. Leaves a film on glasses and utensils.
Concerning the Film.(Disregard if this is not an issue)
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic....
Nov 29, 2009 | GE Dishwashers
After cycle is complete my dishwasher doesn't fully drain water.
Concerning the Film(slimy looking substance).
Aug 20, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishes not getting clean
Check the following to address this issue.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
3. Clogged spay arms
4. Water temperature is too low
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
Jun 19, 2009 | GE GLD4600NCS Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Upper spray arms not spraying water
It sounds like you have a model that has a pot washer cycle that blocks water flow to those arms. What cycles are on your keypad? Sounds like you have it set or single rack wash
Dec 08, 2008 | GE Profile PDW8400J Built-in Dishwasher
Dishwasher detergent does not dissolve entirely. Gel is still on side and powerball tabs doe not dissolve. Dishes are not clean. It sounds like it goes through the cycles properly.
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
5. Not enough soap
Dec 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
GE 24 in. GLD4100L Free-Standing Dishwasher Logo
100 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
