Question about Sony PlayStation Portable (PSP) Console
My umd's will not load at all
My umd's will not load- the laser does not spin either. help?
  • Anonymous Dec 10, 2007
    the lens of the psp will not read the umd disc i could hear the lens trying to read it ad it always fails
  • 67 Answers
Well unfortunately there is bad news a distant friend had this problem it turned out to be that the laser had infact burn out .This is natural as the heat and current eventually destroy this.
The solution is to get it serviced professionally from sony or if your tech savvy you can open up the psp and replace the laser yourself.Google/youtube is good in this case.
Posted on Dec 10, 2007
Hey there i bright a psp and its not reading the games wat can cause that???
Hello
Switch on on your PSP and remove the UMD that might be inside
When you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red (do not stare directly at the laser)
Inspect to see If the Motor is spinning or not.is it moving slightly?
Take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser,check the cables to the PSP and see if there is a bad connection.
If both are running well then put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be too much pressure for the disc to spin freely
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky do the fpllowing;
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing.
try and scrape the gears themselves to make sure there is no gunk or debris in the gear..
After this try and see if it is reading UMD again.
If none of this is working, it is time to open your PSP unit
If you are able to find out what's wrong from the troubleshooting steps above you can replace the problem by
Replacing the UMD, Assembly,Replacing UMD Disc Motor,Replacing UMD Laser Motor or by Replacing PSP Motherboard
Dec 15, 2010 | Sony Video Game Consoles & Games
My problem is my umd disc is not working in the psp.
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
Dec 03, 2010 | Sony PlayStation Portable (PSP) Console
Umd drive does not spin and laser does not turn on
Call sony and they should give you a new pne free of charge! Thats what happened to me!
Jul 16, 2009 | Sony PSP (Piano Black)
My psp2006 ver5.03 cant read games
PSP UMD Repair: Not reading UMD discs
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Jul 16, 2009 | Sony Video Game Consoles & Games
My psp won't load umd's and all i hear is a scrathing sound
The UMD laser might be dirty or broken. Open up the UMD drive and give the laser a clean with a lint-free cloth. Then pop the disk back in and try again. If that doesn't work, you will need to get the PSP repaired or buy a replacement laser and do it yourself.
Jul 14, 2009 | Sony PlayStation Portable (PSP) Console
UMD on PSP Slim will not spin
No idea, if its not spinning u definitely need to buy a new Laser Assembly. Sry!
Nov 13, 2008 | Sony PlayStation Portable (PSP) Slim...
It won`t read my game
First we will do some trouble shooting with what might be wrong with your PSP unit. About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
if you need more infomation please just ask ... Symo02
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
Help!
You might have PSP stop reading UMD discs, First you will do some trouble shooting with what might be wrong with your PSP unit.
first is the Disc Spinning motor. This will not let The disc in the UMD spin. On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
2nd is something stuck in the UMD gear, try to clean the gear of arm of dust, plastic, soda, and even hair.
and at the last is the actual laser itself. It will not focus the laser to read the UMD disc.
Hopefully this help, Pls post back should you need additional information...!
Jun 01, 2008 | Sony PlayStation Portable (PSP) Console
Umd play
You need to replace your umd drive. your laser is prolly bad or the spinndle wont spin, laser wont move. theres alot reasons for this issue. but the problem can be solved with a new umd drive. you can try to do this your self on have someone professional do it for you.
contact us for help. United.Gamez@Gmail.com
May 25, 2008 | Sony PlayStation Portable (PSP) Console
PSP
Hi Voltagehog,
You need to look intothe UMD drive. Press the little Black probe sticking up in the UMD drive. It is about 3/4 inch from left and 3/4 inch from top of the UMD drive. When you press it, look for the Disc spindle to rotate, and the Laser to light up and the Laser movement to occur. This will tell you a lot in what is working or not in the UMD drive. If the laser does not move left and right, or light up, you have a problem with the laser. move it manually with a pen or something, Only click it a couple of times. Try the black button thing again. If the Disc spindle motor does not spin. You probably need a new UMD drive.
If you need a new UMD drive, click on "repair directory" at the bottom of this screen, Click on Video game Consoles. Pick out a good service out. I know one of them specializes in Playstations.You can get a new UMD drive replaced for under $60.
Nov 15, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
