Question about Lakewood HV 18-c Floor / Box Fan
My lakewood HV18 just stopped. Spinning the shaft
My lakewood fan HV18 just stopped. Spinning the shaft does no good. I'm thinking it's a capacitor. Company went out of business in May. A local company MCM electronics sells all sorts of capacitors. Or perhaps a motor rewinding company might be the ticket. I will put capacator on a meter! What do you think?
  • 512 Answers
I think you need to buy a new fan. Unless this thing cost several hundred dollars it isn't worth rewinding and a capacitor isn't likely to cause it to stop working, the cap is for STARTING it spinning anyway and sometimes they are used to HELP it run better, but it will try to run if you spin it and since your's does nothing, more than likely the windings are gone.
Posted on Sep 09, 2009
  • 1 more comment
  • mrfixit67 Sep 23, 2010
    in the wiring to motor winding connection inline on the white wire there is a small temperature cutout sensor they often go bad and have no continuity.You can simply open the motor case and remove this faulty temp cutout connect the wires without this between them and it will work fine. I have removed several from different fans when the went bad and the fans run just fine to this day.
  • ianvalerio Aug 10, 2011
    mrfixit67 THANK YOU!!!!!!!!!!!!!!!!!!!!!!
  • Ken Belanger Jul 20, 2013
    Thank-you as well. For others attempting this, I found the thermal fuse underneath some black heatshrink under the ends of two wires against the motor. I cut our the heatshink twisited the wire end together and soldered them. If I was to do it again, I would just connect a wire between the capacitor terminal where blue wire comes from the motor and the white wire at an easy location. No need to deal with cutting open the hink shrink and potentially damaging a fragile winding.
Lakewood fan mc42 will not run on low speed change switch no help
hello Lamar baker i think the problem is the AC CAPACITOR is about 2 to 5 micro farad this is usually the problem if your sharp and bossing is clean and have oil...
Jun 22, 2015 | Lakewood Dryers
Thermal protection
The thermo protection is located under the shrink wrap where the blue power wire comes into connection with the motor field winding and the cap feed. The continuity between the plug end and the blue wire at the Capacitor will be broken.
Jun 02, 2013 | Lakewood HV-14/C Fan
I HAVE A LAKEWOOD FAN MODEL # HV-14C, and the motor would stop after running the fan for awhile but now the fan does nothing ? now what?
Hi, If you have no sound at all and the fan stopped in mid-use it is probably the thermo protection located under the shrink wrap where the blue power wire comes into connection with the motor field winding. The continuity between the plug end and the blue wire at the Capacitor will be broken. Great care must be taken to prevent breaking the winding wire. The thread-like wire that is painted with varnish or shellac is connected befor the thermo protector, so you don't really have to actually open it up, rather, simply jumper the connection with wire of same gauge and put the new thermo protector inline just befor the capacitor.
Jun 24, 2012 | Lakewood HV-14/C Fan
My lakewood high speed floor model HV-21T stopped running. After shutting off it started running again but shut off again and this time the motor and cage was extremely hot.Also are new motors available on...
Try replacing the "start-run" capacitor. It is the rectangular black box mounted on a tab next to the motor inside the cage, two wires attached (cut them close as close to the capacitor body as possible). Other symptoms include not moving at all with a hum, and getting very hot. The capacitor is a 5% tolerance 8 microfarad rated at 250vac. It doesn't have to be the exact form factor but it does have to be heat rated at or above 70C per design parameters of the fan.
WARNING! Make sure to protect the leads properly because this capacitor is connected directly to the power mains during operation. If one of the leads electrically shorted against the fan housing or cage could cause a catastrophic failure of the fan, and possibly a fire, and possibly give a nasty shock to whoever was switching on the fan at the time.
-Brandon
Aug 22, 2010 | Lakewood HV 18-c Floor / Box Fan
Coleman RV Roof AC Fan Issues
It sounds like you have a bad fan capacitor.
You might try replacing it, they don't cost very much.
Sep 22, 2009 | Dometic Rooftop RV Air Conditioner
Fan slows down and also stops suddenly on its own
motor windings are going bad. The winding swell as electricity goes through them putting pressure on the shaft. The reason it shuts down is for safety so it won't overheat and start a fire. Recommend replacement. Hope this helped Good luck
Dave
Sep 16, 2009 | Lakewood 16" Stand Fan
Need help with fixing my lakewood floor fan.
try cleaning it and put oil especially at the base of the shaft.then try wiggling the shaft for bushing tolerance.if you feel the shaft wiggles to wide, then you'll need to replace the bushing and the shaft.but before anything else check the thermal fuse.it is found on the motor itself or try to borrow a tester with resistance measurement to check for continuity of the winding by connecting the probes with the plug, one each terminal.then turn the fan on.the pointer should move if its ok, unless burn out.if not.then the thermal fuse blow-out.
May 28, 2009 | Lakewood HV 18-c Floor / Box Fan
Lakewood HV 18-c Floor / Box Fan Logo
1,008 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
