Question about GE Profile WPSR3120WWW
My GE washer won't pump. It clicks at that part of the timer. It does agitate so the motor is good. Is it the timer?
  • GE Master
  • 8,220 Answers
I bet you have strings or coin in the pump impeller.. Remove the front panel remove the pump. Take it apart and clean it out.Easy fix.
MANUAL
Posted on Sep 10, 2009
Replacement motor for a ge washer
drop the belt off
make sure its not the timer
look for a local ge parts supplier or washing machine all makes part shop local to your area
GE Filters Parts
Jul 01, 2016 | GE Washing Machines
Enter service mode, GE GTWN5650FWS washing machine. won't spin or agitate...just makes clicking noise. drain pump works. timer counts down.can I check the transmission operation by putting mac
NOT SURE WHAT UR MACHINE WILL DO IN SERVICE MODE BUT DOUBT IT CHECKS TRANNY? THE LIKELY CULPRIT IN UR CASE MAY BE A DEFECTIVE DOOR SWITCH? OR WORN MOTOR COUPLER ( BETWEEN TRANNY AND MOTOR) DOUBT ITS UR TRANNY?
Sep 26, 2014 | Washing Machines
Ge frontload washer seems like it is not aggitating... what would be the problem???
Hello there:
The first thing to check when your GE washer is not agitating, is the belt. Let me tell you how to check the belt & the clutch with out having to take the washer apart.
The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
If the washer drains the water and then spins the way that it should, this tells you that the motor, belt & clutch are not the reason why your washer won't agitate.
A broken belt could be the reason your washer is not agitating or spinning.
The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
The agitator uses a plastic agitator coupler that is couple to the transmission shaft by using splines cut in the coupler and on the transmission shaft.
Too much usage or overloading the washer too many times will wear the agitator coupler splines. With out the splines the coupler could not be coupled to the transmission shaft and that could be the cause why your washer is not agitating.
The clutch: A bad clutch could also be the reason the washer won't agitate or spin. Usually when the clutch is bad the washer will be noisy, like when you have bad brakes on your car.
The transmission: The transmission could be the reason your washer is not agitating. A common problem with the transmission is oil leaking right on top of the motor pulley and the belt.
As you can see, there could be different reasons why your GE washer is not agitating. You just need to keep checking each part until you find the problem and replace the part responsible.
Oct 03, 2010 | GE WSXH208A Front Load Washer
2008 GE Washer that won't spinor agitate. Belt is
check the carbon brushes on motor .... and check pressure switch ... its a round unit with sethropugh pipe going to it.. blow GENTLY in hose hole should hear a clicking noise ...(TURN ELECTRIC OFF FIRST)
Jan 04, 2010 | Washing Machines
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Old GE Washer WNSR2100T8WW will not pump out water nor spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 12, 2007 | GE WJSR2070B Top Load Washer
Will Not Agitate!
try replacing the drive bell, which is underneath the agitator. take the agitator off and unscrew the drive bell. remove and replace. the drive bell is most likely stripped.
Mar 29, 2007 | GE WDSR2080D Top Load Washer
Washing Machines Logo
88 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
