Question about Casio Exilim EX-Z750 Digital Camera
My camera lens will not go back into the body of the camera. I dropped it with the lens out.
  • 428 Answers
Since the camera actually dropped, Chances are that this caused the damage. You need to take it for repairs. Then you find out that other parts may be broken as well.
Posted on Sep 10, 2009
5 Suggested Answers
dbarchitect
  • 150 Answers
SOURCE: I have a zoom lens
Sorry, it will require service repair. Contact your local photo shop, go back to where you bought it and have them help you with service warranty, or contact Nikon directly for service support.
Posted on Jan 21, 2009
SOURCE: Lens will not retract
As bad as I hated to, I purchased a new camera for $109.00 vs. $90.00 for the repair. I still intend to look around for a similar camera,maybe on eBay or at a yard sale for parts. I think that I would like to give the repair a whorl. I can't tear it up any worse ... it does not work now!
Thank you for allowing me to post ...
R
Posted on Jun 21, 2009
  • 11967 Answers
SOURCE: I dropped my Canon EOS Rebel Xti in the canal while kayaking.
Water in the camera body could take up to a week to dry. If you tried turning it on while it was wet inside, you may have shorted out some circuits.
Posted on Aug 23, 2009
SOURCE: Camera was dropped & the zoom lens will not
Unfortunately this needs to be returned to your dealer to be repaired properly
Pushing or pulling the lens is futile.. unless you are extremely lucky
This usually signifies the end of the the cameras life as you can buy a new camera for the cost of the repair!
Posted on Sep 23, 2009
I have a canon eos Rebel DXS - I dropped it and now it won't focus.
Normally I'd say your camera is due for a trip to the service department but, depending on the surface the camera was dropped on and did it hit lens first or body. So without knowing let me ask you to do this. Remove the lens and quickly install the body cap on the camera. Hold the lens firmly in a hand and shake it vertically gently but with a little vigor listen for a rattle, stop, do it again horizontally listen for a rattle. If it rattles the lens has internal damage if not and the camera appears to be functioning then I'm going to instruct you on how to clean the gold contacts on the lens and body.
Using a new pencil with a red rubber eraser gently rub/clean the gold contacts while holding the lens almost vertical with the contacts facing down, use a puffer/blower to clear away the rubber dust. On the camera body, remove the body cap and hold the camera with the lens mount facing down as best possible and clean the tinny gold contacts with the red rubber eraser. DO NOT use a puffer/blower or blow on this part to remove eraser dust. Keep the camera lens mount facing down as much as possible and use a lens tissue to clean away any rubber dust. When you have completed this install the lens on the camera and make sure it clicks and locks solidly. Try your camera again, if it works great if not it means there is an electrical break within the camera or lens and it needs to got to a service depot. Hope everything work for you
Jan 02, 2011 | Canon EOS Rebel XSi Digital Camera
I dropped my Nikon d50 and now when I turn it on it flashes fEE. Whats wrong?
The lens is not making proper contact with the camera. Try removing the lens, cleaning the contacts on both the back of the lens and in the lens mount on the body, then reattaching the lens. If that doesn't do it, try jiggling the lens gently. If that doesn't do it, try attaching a different lens if you have one available, or attaching the lens to a different body if that is possible. If nothing works then it could be that the lens and/or camera needs servicing after the drop.
Apr 25, 2010 | Nikon D50 Digital Camera
Aug 23, 2009 | Canon EOS 400D / Rebel XTi Body Only...
I dropped my Powershot SD 500 and now the lens cover does not cover the lens. It leaves a gap when closed and does not retract all the way when open. It seems that the resolution on some of my photos is...
A bit of gentile persuasion may be necessary.
Have you tried to push the lens into the camera body?
I believe that the camera has lost track of where the lens is in it's range of travel.
use your finger and see if a small amount of pressure will put the lens back ito position.
In the end, this is not a new camera, if it is dead a better replacement can be had for as little as 120 $US
Jul 27, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
The lens wont go back in and it wont turn on help
Sorry to tell you but you have to send the camera in for repairs. The 1st frame and cam frame could be damaged or could need resetting and alignment. Please dont force it back into the camera body as you could cause more damage which would make the camera unrepairable/too costly.
May 12, 2009 | Cameras
Nikon AF 35-135 lens
Did the only the lens drop or was the lens attached to the camera body? If the lens was attached to the camera, you need to verify that the problem is in fact the lens and not the camera body. The easiest way to do that is to try a different lens on your camera body or your lens on a different body. If you do not have access to either, I would find a local camera store that sells Nikon equipment. I am sure they will let you put your lens on one of there bodies. In any case, ff the damage is as extensive as it sounds from your brief description, you need to take it to a camera repair man. This is not a do-it-yourself job.
Feb 07, 2009 | Nikon N70 35mm SLR Camera
Got dropped and the lens come out
If you dropped it while 'alive' a piece holding the lens might have been broken. If you dropped it in a dormant state then it could be worse - when at rest the lens is secured fairly inside the body of the camera. Have it checked, I suggest.
Sep 25, 2008 | Cameras
50mm C lens issue
From your description, Yes. All RB67 lenses have common problems, usually sticky blades. Since there are 2 sets of blades, (shutter and aperture), the shutter blades may be contaminated with oil/debris
Apr 19, 2008 | Mamiya RB67 Pro SD Medium Format Camera
Lens damaged camera dropped camera body damaged pentax k1000
"To get the lens to retract, we tried to do a slight twist over to the left (looking at the camera like your the subject - camera lens is facing you). Sure enough it went back in! But now it has trouble focusing. That's another question now. Darn thing...we'll see what else we can jimmy :-)"
quoted from another solution.
Mar 15, 2008 | Pentax K1000 35mm SLR Camera
Ricoh Caplio R4 Lens
This is an easy fix for a camera shop. Just tell them that your lens is off track, and needs to be aligned. It should cost less than $50.00. If you are really good with electronics, you can attempt it yourself. Just let me know if you need the schematic to the camera. Best regards, Bill
May 20, 2006 | Ricoh Caplio R4 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
378 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
