Question about LG WM-2277HW Front Load Washer
Door gasket leaking during wash cycle - LG WM-2277HW Front Load Washer
  • 313 Answers
You can look on the link below to get a replacement gasket if that is what you are looking for.
I hope that is what you are looking for.. Let me know..
Posted on Sep 10, 2009
Leaking water from bottom door over two bolts
Change the door gasket or realign the door.
Jan 12, 2014 | Maytag MHWE201YW
Water leaks with larger louds on kenmore front load eco
Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Feb 01, 2013 | Kenmore Washing Machines
Water leaks on spin cycle
Water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Feb 01, 2013 | Hotpoint Aquarius WD63 Front Load...
Washer is dripping water at the front when filling and washing
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution.It is possible that water can leak if there is gaps on the front door gaskets and must be checked for damaged gaskets which can give poor sealing of the door. So in this case the leak will happen more during the cycle and not on the drain cycle end.
check this video to see how to replace the door gaskets.
http://www.espares.co.uk/advice/washing-machines/a/7/1397/how-to-replace-the-door-seal-on-a-washing-mac.html
Jul 30, 2011 | Kenmore Washing Machines
Water leaks out front center of door during the
Check the door gasket for any damage. A rip or a tear could be the cause of the leak.
Jul 20, 2010 | GE WSXH208A Front Load Washer
My machine has a small water leak though the door during washing
Replace the gasket. Or make sure that the gasket is sealed properly
Feb 10, 2009 | LG WM-2032H Front Load Washer
When the dishwasher is finished the waters still left at the bottom and it leaks while it's washing
Reduce the amount of detergent used,observe it during wash cycle, find out where the water leaks from. it might be through door gasket replaced it.
Aug 13, 2008 | Asko Dishwashers
2-yr old unit is leaking
I had this problem with similiar model, the extended warranty company was out several times, replaced gaskets and many other parts. Still had the problem. The last tech replaced the upper washing arm that hangs below the upper rack, He said there was a defect where water shoots out between the mfg welded seam and shoots water at the door in the right spot to make it leak. He replaced it and haven't had the problem for about 8 months.
Nov 26, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
LG WM-2277HW Front Load Washer Logo
177 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
