Question about Mitsubishi WS-55859 55" Rear Projection Television
Mitsubishi WS-55859 distorted picture, distorted colors...
My Mitsubishi ws-55859has a series of thin green lines that go from left to right across the screen in an arc. The color above the lines is fuschia/hot pink and prety normal below. There is some ghosting right along the yellow lines. Anyone know what is wrong? How much to fix and how to do it?
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Sep 09, 2009
Mitsubishi WS55859, was getting 2 and 2 blink, replaced the pico fuses and convergence chip - 3 times, each fix worked better than the next but evenually failed - now have it working, trying to adjust...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Color is distorted....picture is like watching 3d
convergance amps have failed about 300 hundred to fix
Sep 28, 2009 | Mitsubishi WS-55859 55" Rear Projection...
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
My mitsubishi WS-55859 picture is not as clear as it should be and there are horizontal lines across the middle 1/3 of the screen. I also notice a green ghosting on some images and some colors. Any ideas?...
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 13, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi 55859 Blinking Green Light
Video instructions for repairing Mitsubishi WS-55859 HDTV:
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
You can find the parts (capacators) at Radio Shack for appx. $2/each.
Dec 27, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55859 parts
time to get a new one.
even you get the main board, you might have other problem that has not show up yet.
Oct 05, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Green Screen
Did you find out anything? Mu 60" is doingthe same thing.
Jul 26, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55809
1)Check for coolant leak from CRT onto signal board
2)Possible convergence problem ..................T.
Oct 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
167 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
