Question about Daewoo Washing Machines
I want to buy a Daewoo washing machine in barcelona. Which shop?
I want to buy a Daewoo washing machine in Barcelona, Spain. I couldn't find it in any big store nor shop. How do i order one? I want model DWF 200MS 10kg. Top load only. All major department stores don't want to have to do anyhting with this kind. Thanks,S
masteria
  • 355 Answers
SOURCE: what is LE error for Washing Machine Daewoo DWF
In other Daewoo models LE error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles.
Good Luck!
Posted on Jun 16, 2009
  • 1294 Answers
SOURCE: daewoo dwf-6094r wont spin on spin cycle
You need to clean out your outlet filter;(which is accessible thru the front bottom right side of machine, small push door, or plastic screw) this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. For the pump, tubes, etc you hav to open up behind the machine. Be prepared for water to come flowing out.......
And rate me pl, if the solution has worked......
Posted on Dec 02, 2007
SOURCE: daewoo washing machine dwf-75ts
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
Posted on Jun 10, 2008
  • 215 Answers
SOURCE: Water overflowing during use
Seems like blockage in pressure system, machine will always think it is empty if so. Pressure system is under the lid, a round switch with a thin pipe going to it. At bottom of this pipe it is probably blocked with limescale or residue from detergent.
Posted on Feb 12, 2010
ZJLimited
  • 17970 Answers
SOURCE: LE CODE WHAT MEANS. DAEWOO
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
Posted on Apr 21, 2011
I have 2 paragraphs that I need help correcting the subject-verb agreement
I corrected it for you. I am 63 and British educated in written English to degree standard. I added 2 commas, added a couple of words, removed speech "quotes" for emphasis 'quotations' and removed all the dashes - as - they aren't required. I have also broken it into paragraphs for readability.
There is, in beautiful Barcelona, Spain, many surprises to be found. Barcelona, Spain's second-largest city, and Madrid, the country's capital, has enjoyed a traditional rivalry. At one time, the population of Barcelona were forbidden to speak the city's native tongue, Catalan, by a royal decree from Madrid. Today, however, neither Spanish nor Catalan are discriminated against in the region.
One of the sites that belongs on every tour, the outlandish cathedral La Sagrada Familia ('The Sacred Family'), was designed by Antoni Gaudi. Everyone using the word "gaudy" actually has Gaudi's name on his or her tongue.
A series of thirteenth to fifteenth century palaces now house the Museo Picasso, which display a history of Picasso's work and his many years living in Barcelona. Les Demoiselles d'Avignon, or The Young Ladies of Avignon, are one example of a painting inspired by his time in Barcelona.
Whether you prefer cobblestone streets with centuries old buildings or asphalt streets with modern shops and taverns, each are to be found in Barcelona. At night, every one of the streets seems to have a festive air, reflecting the vivacity of Spanish culture.
May 29, 2015 | GPS
How do I find a burial site in barcelona for 2005
pergunta lo a l'ayutamiento de Barcelona.
Sep 22, 2014 | Computers & Internet
I couldn't find Singapore airlines email address
Please read the following, it could be useful:
City Office
Address
Singapore Airlines
Passeig de Gràcia 50
2nd Floor Unit 2a
Barcelona 08007
Spain
OCS Mail Stop: BCN TWN 02A
Phone 902 380 777 (Reservations - within Spain)
+34 934 873 908 (International)
Fax +34 934 872 733
Email es_feedback@singaporeair.com.sg
Airport
Address
Singapore Airlines Ltd.
Aeropuerto de Barcelona
Terminal 1, Dique Sur, P10, Zona S,
Oficinas 70-73,
08820 El Prat de Llobregat,
Barcelona,
Spain
Phone +34 932 971 308
Fax +34 932 971 310
Baggage Office
Address
Flightcare
Lost and Found Department
Arrival Hall Terminal A
Barcelona Airport
Phone +34 932971076
Telex BCNLL8X
BCNKKSQ
Call Centre 24/7 (Singapore)
Phone +65 6223 8888
Fax +65 6786 6947
Jul 29, 2011 | Computers & Internet
I lost my battery charger for my pentax optio m30 in Spain. Can I buy a replacement in Barcelona?
I'm sure you can. Simply scout around the better shops. One of them is sure to have it.
Here is an address for Pentax distributor in Barcelona:
Reflecta S.A. C / Europa 8 , 08028 Barcelona
tel: (34) 93 33 91 154
Hope that helps, and don't forget a fixya rating!
May 08, 2008 | Cameras
Washing Machines Logo
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
