Question about HP LaserJet 4350 Printer
How many pages per minute will the laserjet 4350 print?
  • 776 Answers
It is designed to blaze through 55 pages per minute for an ample network, and gives on an average 50 pages a minute
Posted on Sep 09, 2009
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
My HP Laserjet 4350 is printing 3 copies all the time even the test page.
Press the green button (with the "check" sign on it), then press the "down" arrow button four times.
The display should read "configure device".
Press the green button again.
Press the down arrow one time? until you see "printing".
Press the green button.
Scroll down to "copies"... it probably reads "3".
Set it back to "1" and then press the green arrow button.
Nov 02, 2010 | HP LaserJet 4350 Printer
LaserJet 4350 Printer: 49.2f02 service error on hp 4100 printer...
Turn the printer off for a few minutes and then back on. If that does not fix the problem, try to have the print queue cleared and tray again. Most of the time it's a PDF file that causes this problem. If that does not fix it, it may need a new Jetdirect card.
May 16, 2010 | HP LaserJet 4350 Printer
HP Laserjet 4350 not recognizing addtional paper trays
Print a CONFIGURATION Page. On the 1st sheet/right side near the bottom will be a list of the trays that the printer detects. If all the trays are there, then your print drivers need to be reloaded. If the CONFIG page doesn't see the extra trays, then the tray may have a bad connector. You might want to try a COLD RESET.
May 12, 2010 | HP LaserJet 4350dtn Printer
4350d prints 2 pages for every 1 page received
Your Printer Preferances is probably set to 2... solution is
Go into Control Panel > Printers > right click on the 4350 and choose Properties.
Look for Printing Preferances button near the bottom and click it.
Choose the Advanced tab and make sure Copy Count is set to 1
Sep 23, 2009 | HP LaserJet 4350 Printer
Need to change the left margin of a HP 4350 printer
go to the File menu of the application you are using, then click Print Properties or Page Setup. From there, you may adjust the left and rught margins.
Dec 05, 2008 | HP LaserJet 4350 Printer
HP laserjet 4350 DTN Folding corners
teflon coating on heat roller in fuser is coming apart. replace the fuser. also check to make sure the paper tray is set to the correct size. this means pull the tray out, remove all paper, look inside to make sure the arrow is pointing directly at the correct media size you are using i.e. letter or legal or whatever you are using. Good Luck! please rate this carefully.
Oct 09, 2008 | HP LaserJet 4350dtn Printer
HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Aug 08, 2008 | HP LaserJet 4350 Printer
Hp laserjet 4350 printing slow down
Look on the left side of the tray. There should be 3 white fingers that stick out. Make sure they aren't broken or out of place. Also slide the paper size lever and make sure they work properly. There is also a custom and standard switch. Try to print out of the MP tray(fold down tray). If it prints normal speed, you probably have a problem with the tray.
Nov 15, 2006 | HP LaserJet 4350 Printer
HP LaserJet 4350 Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
