Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Dishwasher FDB1050REMO - built in, no power and no lights. Tried the breaker and nothing, is there a reset function on this model? Any ideas?
  • 415 Answers
No reset on unit but items to check is have a voltage meter remove the lowest kick plate open the wire connection box it may just be a bad wire nut. Do you have voltage if so then the problem is the thermal fuse located on the pcb controller between the outter door panel and the inner door panel
Posted on Sep 09, 2009
My electrolux dishwasher model EWDW6505GS0 will not turn on. The electronic display only indicates "Welcome" for a split second and then goes out and nothing lights up on the panel and cannot get it to...
Good Afternoon Will, thank you for allowing me to assist you!
How long did you leave the breaker off? It is important to wait roughly ten minutes and then your dishwasher on. If resetting the power does not correct the issue, then it sounds like your dishwasher could possibly be experiencing a communication error with the control board/panel or a potential wiring failure. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Jan 11, 2014 | Electrolux EWDW6505GS Fully Integrated...
I have a Whirlpool Dishwasher Model #GU240CXTPB1. The normal light won't stop blinking. Tried turning the breaker to reset, but still blinks. No other button works.
Whirlpool dishwasher reset sequence is usually to hit the heat dry then normal then heat dry then normal buttons within 5 seconds and it usually resets.
Mar 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
D/w quit when garbage disposal drain clogged,, now I have no power lights and nothing ,,, no breaker are blown.?
you might try resetting the breaker(turn it off then back on) I would wait, say 5 min before turning breaker back on to see if it resets the microprocessor on the control module.
Dec 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool DU1100XTPS 9 Dishwasher acts as if no power
Is your dishwasher have a power cord and plugged into a wall outlet under the sink if the answer is yes then maybe the GFI outlet has tripped and all you need to do is reset the button on the outlet
Sep 22, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwasher not responding
we have a 4 yr. old built in dishwasher,model #665-15812,the lock-on light is blinking,and the wash and rinse lights are on,but if we push start ,it won't,and if we push the clear button,it won't clear,it's like it's stuck ....we've tried un-plugging,etc....any ideas,on what to do??? donnie-sue79
May 13, 2009 | Kenmore 15939 Built-in Dishwasher
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Dec 03, 2008 | Kenmore 15899 Built-in Dishwasher
JDB3610AWX - Controls (pushpad) does not respond to input (doesn't turn on, led doesn't light)
in the manual there is a sequence to unlock the control check the manual for the unlock sequence
Apr 25, 2008 | Jenn-Air JDB3610 Built-in Dishwasher
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
321 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
